Cisco Document Team
Administrator
Administrator
The Cisco Document Team has posted an article.
This document describes how to remove or modify the NetFlow configuration on Firepower Threat Defense (FTD) via Firepower Management Center (FMC).
Know of something that needs documenting? Share a new document request to [email protected]
Your input helps! If you find an issue specific to a document, please let us know. Remember to provide as much detail as possible when submitting a request or feedback on an existing document including information regarding the section, area, or issue you had with the document and what could be improved.
You can provide feedback in a few ways:
  • Using the Feedback button located at the right panel of the corresponding article.
  • Submitting your feedback on an existing article or video, or new document request to [email protected].
  • If you are opening a TAC (Technical Assistance Center) case, you can notify your engineer of the gap or missing content and they can create a request on your behalf.
See How Cisco TAC is transforming documentation and simplifying self-service in this blog
vera123goodin
Community Member
Thanks for sharing. I found a lot of interesting information here. A really good post, very thankful and hopeful that you will write many more posts like this one. The solution worked for me thanks to the community and the members for the solution.
