Meddane
Lab security implementation from scratch including the following:
Part-1: Basic configuration of all routers and Cisco ASA
Part-2: Modify the default MPF application inspection global service policy
Part-3: Configure a Synchronized Time Source Using NTP
Part-4: Configure Zone-Based Firewall on R1
Part-5: On ASA configure address translation using PAT for the inside network
Part-6: Configure static NAT and ACL for the DMZ server
Part-7: On R1 configure address translation using PAT for the inside network 10.1.1.0/24
Part-8: Configure ASA Clientless SSL VPN Remote Access
Part-9: Configure ASA AnyConnect SSL VPN Remote Access
Part-10: Configure the Site-to-Site IPsec VPN Tunnel between R1 and ASA
