on 03-30-2011 10:25 AM
IOS-XR has a very strong embedded mechanism to do user authentication and authorization. While XR does not have the concept of privilege-levels as what IOS had, the embedded user task group management is extremely strong allow for the creation of different task groups.
Building blocks for on-box authorization scheme
4 types of permissions per task
Tasks | ||||
aaa | config-services | hsrp | netflow | sbc |
acl | crypto | interface | network | snmp |
admin | diag | inventory | ospf | sonet-sdh |
atm | disallowed | ip-services | ouni | static |
basic-services | drivers | ipv4 | pkg-mgmt | sysmgr |
bcdl | eigrp | ipv6 | pos-dpt | system |
bfd | ext-access | isis | ppp | transport |
bgp | fabric | logging | qos | tty-access |
boot | fault-mgr | lpts | rib | tunnel |
bundle | filesystem | monitor | rip | universal |
cdp | firewall | mpls-ldp | root-lr | vlan |
cef | fr | mpls-static | root-system | vrrp |
cisco-support | hdlc | mpls-te | route-map |
config-mgmt | host-services | multicast | route-policy |
The following task-groups are predefined in IOS-XR
root-system: Root system users
root-lr: Root logical router users
netadmin: Network administrators
sysadmin: System administrators
operator: Operators performing day-to-day activities
cisco-support: highest level of privilege allowing lowest level access
If you are unsure as to what task group and permission level you need in order to allow a certain command, use the "describe" keyword.
Example:
RP/0/RSP0/CPU0:A9K-TOP#describe show bgp summary
User needs ALL of the following taskids:
bgp (READ)
So in order to allow a user to do the command "show bgp summary", we would need to allow the following line in
the task group definition:
task read bgp
It can also be the case that a particular user needs to be member of a particular (pre defined) task group.
such as a Process restart, you can only do when you are member of cisco-support:
RP/0/RSP0/CPU0:A9K-TOP# describe process restart bgp
cisco-support (EXECUTE)
In regular IOS-XR configuration define your task-group with the permissions and tasks you like
RP/0/RSP0/CPU0:A9K-TOP(config)#taskgroup basic-admin
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task read acl
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task read bfd
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task read bgp
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task write acl
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task write bfd
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task write bgp
RP/0/RSP0/CPU0:A9K-TOP(config-tg)# task debug bgp
You can also define a user group that imports several task groups:
usergroup noc-staff
taskgroup operator
inherit usergroup all-users
As mentioned, XR doesn't have priv levels, but in order to leverage the existing AAA profiles from TACACS used for IOS based routes, we can create user-groups that are named as the privilege levels:
usergroup priv15
taskgroup root-system
taskgroup cisco-support
Now with tacacs we can send the priv via the options in service-exec:
service = exec { priv-lvl = 15 }
or via a radius AVP like:
cisco-avpair = "shell:priv-lvl=15"
NOTE: the syntax of "cisco-avpair" and the capitalization is dependent on the dictionary definition for the cisco avp.
For starters you need to point your user authentication to the external source for authentication:
aaa authorization exec default group tacacs+ local
aaa authentication login default group tacacs+ local
when you add the following to your tacacs profile :
TACACS:
service = exec {
task = "rwx:bgp,#operator"
RADIUS:
Cisco-AVPair = "shell:tasks=#sysadmin,rwx:bgp,r:ospf"
you'll inherit the read, write and execute permissions to BGP as well as the user will be part of the local operator group definition.
Either this group is part of the standard cisco embedded groups or it can be something that you have defined locally.
the radius profile allows read/write/execute on BGP, read for OSPF and membership to the sysadmin group
By using AAA you can either reference locally defined task groups OR you can define the task groups in the tacacs/radius response packet
or using a combination of both
To find out which groups you are currently member of while being logged in:
RP/0/RSP0/CPU0:A9K-TOP#show user tasks
Wed Mar 30 18:26:00.768 UTC
Task: aaa : READ WRITE EXECUTE DEBUG
Task: acl : READ WRITE EXECUTE DEBUG
Task: admin : READ WRITE EXECUTE DEBUG
In IOS we can do command authorization for each separate priv level. in XR we don't have priv levels hence either command author is enabled for ALL commands or none at all:
RP/0/RSP0/CPU0:A9K-TOP(config)#aaa authorization commands default group ?
WORD server-group name
tacacs+ Use list of all TACACS+ hosts
Note: in order to do command author you must use TACACS, you cannot use radius.
n/a
Xander Thuijs - CCIE #6775
Sr Tech Lead ASR9000
• sysadmin: Has the ability to control and monitor all system parameters but cannot configure network protocols.
Trying this
Above group have some write permissions :(
Hi Xander,
Great topic!
My quick question, can I make all tasks to read permission?
But I don't want to define any new user group or task group in the router.
I use Cisco ISE (with device administration) to authenticate and authorize user login into router.
I use TACACS+ protocol.
I tried to define task=r:acl,r:aaa,r:admin, (define all tasks with 'r' permission) on Cisco ISE as AAA server but when I login, it said no taskid available.
My goal is, read-only user able to do any show commands, include show run but they are not able to do any configuration
Thank you in advance
what is equivalent for the user groups and task groups at Nexus 3k ?
how to apply those at Nexus ?
How I can deny the command "no router static" but allow the commands inside of router static//address-family ipv4/ipv6??
Hi Xander
I have a doubt. Has you changed the task id from 5.3.3 to 6.4.2 version?. I mean, we have an user in version 5.3.3 who can issue the command show bgp sessions | i Established | utility wc -l,
RP/0/RSP0/CPU0:XXXXX#describe utility wc
Package:
iosxr-infra
iosxr-infra V5.3.3[Default] IOS-XR Infra Package Definition
Vendor : Cisco Systems
basic-services (EXECUTE)
I tried to configure the same user in 6.4.2, but I haven't permission to issue this command
RP/0/RSP1/CPU0:XXXXX# show bgp sessions | i Established | utility wc -l
% This command is not authorized
And with other user (root-system) i saw that
RP/0/RSP1/CPU0:XXXXX#describe utility wc
Package:
iosxr-infra
iosxr-infra V6.4.2[Default] IOS-XR Infra Package Definition
root-lr (EXECUTE)
Is necesary to have root-lr to issue "utiltiy"??. Is there any way to issue the command without being root-system?
Hi Xander,
Can You help me out clarify if Radius authentication for SSH access to OOB (MGMT) interface in VRF on ASR9k is supported? Same MGMT interface is used to source Radius packets.
Everything works fine if MGMT interface is not in VRF instance, but after adding VRF it stops working (source IP address is virtual address used by RSPs).
From traces on Radius server I can see that only IOS XR test Radius Access-request and Acounting-Request messages are correctly sent to Radius server. Radius messages contain correct Radius AVP's.
When trying to SSH to ASR, in debug radius output it looks like IOS XR is having trouble fetching attributes (NAS IP, ...) and throws this log:
Failed to send the request to radiusserver :'RADIUS' detected the 'fatal' condition 'No server information is available'
It would help me a lot if You can help me out with this.
Thank You!
BR,
Vladimir
