lamarsh
Level 5
Level 5
Overview
Cisco WAN Automation Engine (WAE) Design is an important component in the Cisco WAE solution. WAE Design standalone software can run on multiple platforms, standard laptops, or desktops. Using WAE Design software, you can plan, engineer, and forecast network operations to help ensure network efficiency and cost effectiveness under all operational conditions. In this demonstration, you use sample plan files that come with the WAE Design application to simplify your WAN environment while making it fully open and programmable.
Check it out here: Cisco WAN Automation Engine 6.2 Design v1.1
Scenarios
  • Scenario 1: Exploring WAN Automation Engine Design Features
  • Scenario 2: Exploring WAN Automation Engine Design Add-Ons
  • Scenario 3: Exploring WAN Automation Engine Design Multi-Layer
Requirements
RequiredOptional
  • Laptop
  • Cisco AnyConnect
Components
  • Cisco WAE 6.2 Design client
  • WAE plan files
  • Python
  • Peri
Features
WAE Design
  • State-of-the-art network and traffic modeling technology.
  • Intuitive interface for creating flows, tunnels, and demands.
  • Cloud SDN application suite with advanced PCE.
Topology
