on 01-14-2014 05:36 AM
This document provides an overview for dual stack sessions for ASR9000 BNG, running ipv4 and ipv6 address stacks next to each other for subscriber sessions.
Dual stack refers to the concept of running a subsciber session with an IPv4 address as well as an IPv6 address.
To unravle the complex terminology associated with address assignment in particular to IPv6 this picture below shows the various address assignment options available.
You can also use the framed-ipv6-address radius attribute to provide an address to the subscriber from radius which then will be advertised
via SLAAC (NA/ND) for both PPPoE and IPoE sessions.
The additional attribute ipv6:ipv6-default-gateway VSA can be used to provide the default router in case no dhcpv6 is used for IPoE sessions.
When it comes to "prefix delegation" that is having a large IPv6 like subnet that is shared between subscribers who get a subnet from that subnet sort of speak the following addressing example hopefully visualizes how it all ties together
The following 2 secions provide the configuration for the client side and the WAN side of the CPE
interface GigabitEthernet0/2
description to switch fa0/15
no ip unreachables
ip nat inside
ip virtual-reassembly
duplex full
speed 100
media-type rj45
negotiation auto
ipv6 address prefix-from-provider ::1:0:0:0:1/64
interface FastEthernet2/0.50
encapsulation dot1Q 50
ipv6 address autoconfig default
ipv6 enable
ipv6 dhcp client pd prefix-from-provider
In these examples we are expanding the delegated prefix with a :1/64 and we perceive ourselves to be the ".1" and default gateway.
ipv6 unicast-routing
ipv6 dhcp pool dhcpv6
prefix-delegation pool dhcpv6-pool1 lifetime 6000 2000
ipv6 route 2001:60:45:28::/64 2005::1
ipv6 route 2001:DB8:1200::/40 2005::1
ipv6 route 200B::/64 2005::1
ipv6 route 2600:80A::9/128 4000::1
ipv6 local pool dhcpv6-pool1 2001:DB8:1200::/40 48
More info on IOS dhcpv6 server:
http://www.cisco.com/en/US/tech/tk872/technologies_configuration_example09186a0080b8a116.shtml
Because ASR9000 treats the 2 stacks as a single subscriber, and hence ONE access request and a SINGLE accounting record are generated for both stacks, differences of desired operation exist when it comes to when for isntance to generate an accounting request.
There are 2 key things to consider and of importance:
Sample Topology for the configuration example
hostname bng logging console debugging |
Radius server configuration.
Radius server is listening on 5.5.5.2 with auth-port on 1645 and accounting-port on 1646
radius-server host 5.5.5.2 auth-port 1645 acct-port 1646 key 7 010107000A5955 ! |
COA server or policy-server with ip-address 5.5.5.2 is running
aaa server radius dynamic-author client 5.5.5.2 vrf default server-key 7 03165A0F575D72 ! aaa group server radius RADIUS server 5.5.5.2 auth-port 1645 acct-port 1646 ! aaa accounting service default group radius aaa accounting subscriber default group radius aaa authorization subscriber default group radius aaa authentication subscriber default group radius line console stopbits 1 ! |
DHCPv6 address pool is defined locally within BNG box and local pool is used for ipv6 address assignment to IPv6 BNG clients
pool vrf default ipv6 ipv6_address_pool address-range 2001::2 2001::7dff ! |
DHCPv4 server with ip address 20.20.20.2 is deployed externally and this ipv4 address should be reachable from BNG device. Routing protocols should take care of reachability of 20.20.20.2 from BNG device. DHCPv4 proxy is configured as follows.
dhcp ipv4 profile IPoEv4 proxy helper-address vrf default 20.20.20.2 giaddr 10.10.10.1 ! |
DHCPv4 proxy is enabled on bundle sub-interface
interface Bundle-Ether1.10 proxy profile IPoEv4 ! |
DHCPv6 server is configured and already configured DHCPv6 address pool is referred within DHCPv6 server configuration. DHCPv6 profile is configured as follows with address pool.
dhcp ipv6 profile IPoEv6 server address-pool ipv6_address_pool ! |
DHCPv6 address pool is referred on bundle sub-interface.
interface Bundle-Ether1.10 server profile IPoEv6 ! interface Bundle-Ether1 bundle maximum-active links 1 ! |
Bundle sub-interface with dot1q encapsulation configured with single tag. Subscriber traffic from
CPE should come with single dot1q tag and this vlan tag should match with vlan id 10 configured under bundle sub-interface. In dual-stack IPoE configuration, “initiator dhcp” is configured ipv4/ipv6 l2 connect mode.
Policy-map type control’s name is referred with service-policy
interface Bundle-Ether1.10 ipv4 point-to-point ipv4 unnumbered Loopback1 ipv6 enable service-policy type control subscriber pm-src-mac encapsulation dot1q 10 ipsubscriber ipv4 l2-connected initiator dhcp ! ipsubscriber ipv6 l2-connected initiator dhcp ! ! |
Ipv4 address 10.10.10.1 is default-gateway ip address for pool of ipv4 address allocated to dual-stack BNG clients
interface Loopback1 ipv4 address 10.10.10.1 255.255.255.0 ipv6 enable ! interface MgmtEth0/RSP0/CPU0/0 ipv4 address 9.22.11.3 255.255.0.0 ! interface MgmtEth0/RSP0/CPU0/1 shutdown ! |
Physical interface gigabit0/0/0/0 is configured as bundle interface.
interface GigabitEthernet0/0/0/0 bundle id 1 mode on negotiation auto transceiver permit pid all ! interface GigabitEthernet0/0/0/1 ipv4 address 20.20.20.1 255.255.255.0 transceiver permit pid all ! interface GigabitEthernet0/0/0/5 ipv4 address 5.5.5.1 255.255.255.0 ! |
Dual-stack dynamic-template is configured for dual-stack initiation. “ipv6 enabled” under dual-stack template and ipv4 unnumbered
address, ipv4 urpf configured.
dynamic-template type ipsubscriber Dual_stack_IPoE accounting aaa list default type session periodic-interval 5 ipv4 verify unicast source reachable-via rx ipv4 unnumbered Loopback1 ipv6 enable ! ! |
Class-map configured for dual-stack scenario to match DHCPv6 – SOLICIT and DHCPv4 DISCOVER as sign of life packet
class-map type control subscriber match-any dual_stack_class_map match protocol dhcpv4 dhcpv6 end-class-map |
Class-map “Dual_stack_class_map “ is referred within policy-map. Even session-start is hit based on DHCPv4/DHCPv6 FSOL, template “Dual_stack_IPoE” is activated. Subscriber mac-address is used as subscriber identification and it is authorized with AAA server
policy-map type control subscriber pm-src-mac event session-start match-all class type control subscriber dual_stack_class_map do-all 1 activate dynamic-template Dual_stack_IPoE 2 authorize aaa list default identifier source-address-mac password cisco ! ! end-policy-map ! end |
”show subscriber session all” command shows ipv4/ipv6 clients session active
RP/0/RSP0/CPU0:bng#show subscriber session all Tue Jan 29 12:49:25.237 UTC Codes: IN - Initialize, CN - Connecting, CD - Connected, AC - Activated, ID - Idle, DN - Disconnecting, ED - End Type Interface State Subscriber IP Addr / Prefix LNS Address (Vrf) -------------------------------------------------------------------------------- IP:DHCP BE1.10.ip22 AC 10.10.10.10 (default) 2001::2 (default)
Command “show subscriber session all detail” should show ipv4/ipv6 clients details detailly.
RP/0/RSP0/CPU0:bng#show subscriber session all deta Tue Jan 29 12:49:27.752 UTC Interface: Bundle-Ether1.10.ip22 Circuit ID: Unknown Remote ID: Unknown Type: IP: DHCP-trigger IPv4 State: Up, Tue Jan 29 12:46:32 2013 IPv4 Address: 10.10.10.10, VRF: default IPv6 State: Up, Tue Jan 29 12:46:42 2013 IPv6 Address: 2001::2, VRF: default IPv6 Interface ID: ..d..... (02 00 64 ff fe 01 01 02) Mac Address: 0000.6401.0102 Account-Session Id: 0000001c Nas-Port: Unknown User name: 0000.6401.0102 Outer VLAN ID: 10 Subscriber Label: 0x00000055 Created: Tue Jan 29 12:46:32 2013 State: Activated Authentication: unauthenticated Access-interface: Bundle-Ether1.10 Policy Executed: policy-map type control subscriber pm-src-mac event Session-Start match-all [at Tue Jan 29 12:46:32 2013] class type control subscriber dual_stack_class_map do-all [Succeeded] 1 activate dynamic-template Dual_stack_IPoE [Succeeded] 2 authorize aaa list default [Succeeded] Session Accounting: Acct-Session-Id: 0000001c Method-list: default Accounting started: Tue Jan 29 12:46:32 2013 Interim accounting: On, interval 1 mins Last successful update: Tue Jan 29 12:48:34 2013 Next update in: 00:00:06 (dhms) Last COA request received: unavailable |
”show dhcp ipv4 proxy binding” command is going to show ipoev4 clients created with ip-address and mac-address, interface on which it is created, vrf-name etc
RP/0/RSP0/CPU0:bng#show dhcp ipv4 proxy binding Tue Jan 29 12:49:42.955 UTC
Lease
MAC Address IP Address State Remaining Interface VRF Sublabel -------------- -------------- --------- --------- ------------------- --------- ----------
0000.6401.0102 10.10.10.10 BOUND 3409 BE1.10 default 0x55 |
RP/0/RSP0/CPU0:bng#show dhcp ipv4 proxy binding de Tue Jan 29 12:49:49.498 UTC MAC Address: 0000.6401.0102 VRF: default Server VRF: default IP Address: 10.10.10.10 Giaddr from client: 0.0.0.0 Giaddr to server: 10.10.10.1 Server IP Address: 20.20.20.2 Server IP Address to client: 10.10.10.1 ReceivedCircuit ID: - InsertedCircuit ID: - ReceivedRemote ID: - InsertedRemote ID: - ReceivedVSISO: - InsertedVSISO: - Auth. on received relay info:FALSE Profile: IPoEv4 State: BOUND Proxy lease: 3600 secs (01:00:00) Proxy lease remaining: 3403 secs (00:56:43) Client ID: 0x00-0x00-0x64-0x01-0x01-0x02 Access Interface: Bundle-Ether1.10 Access VRF: default VLAN Id: 10 Subscriber Label: 0x55 Subscriber Interface: Bundle-Ether1.10.ip22 |
“show dhcp ipv6 server binding” is going to show ipv6 address allocated from DHCPv6 local pool
RP/0/RSP0/CPU0:bng#show dhcp ipv6 server binding Tue Jan 29 12:50:04.560 UTC Summary: Total number of clients: 1 DUID : 00030001000064010102 MAC Address: 0000.6401.0102 Client Link Local: fe80::200:64ff:fe01:102 Sublabel: 0x55 IA ID: 0x0 STATE: BOUND IPv6 Address: 2001::2 (Bundle-Ether1.10) lifetime : 600 secs (00:10:00) expiration: 399 secs (00:06:39) RP/0/RSP0/CPU0:bng# |
Configuration example and verification provided by Narendiran Rajaram
Xander Thuijs CCIE #6775
Principal Engineer ASR9000, IOS-XR and NCS6000
I have two specific Questions.
1. Can there be a specific Docs for Local DHCPv4&6 and aslo PPPoE Dualstack (v46) as well.
2. Is it possible to have both Dual Stack DHCPv4&6 and also PPPoE DualStack (v46) on the same VLAN or i would rather say Access Interface.
The reason why i would do this cos if we want to introduce what ever we want without disrupting our current implementation. I mean lets say if we already do PPoE Dualstack on VLAN A now, and we want to deploy DHCPv46 on the same VLAN given that we do not have to change our current MSANs port VLAN but instead just configure DHCPv46 from Clients or PPPoEv46 from Clients as well.
About the written document by former empl
oyed Xander .. it is possible the BNG ASR9K can generate the accounting start radius attribute as soon the first AF comes up, being IPv4 or IPv6, or wait for a determined period of time and generate a single accounting start record for BOTH AF's.
Somebody can help me to identify which is the command to configured so that the bng sends only one accounting start radius record for both AF's?
Regards Javier
