xthuijs
Introduction
This document describes how to work with and implement QOS Policy Propagation for BGP, or in short QPPB.
QPPB is the concept of marking prefixes received from BGP with a certain QOS group assignment and this QOS-group can be used
in egress policies (or even ingress policies after marking) to perform certain actions.
While this seems so simple, and it is technically, the ability to achieve this functionality in hardware is quite complex.
In this article I hope to unravle some of these gotcha's and operation when it comes to QPPB.
Support
QPPBwith egress qos policy is supported in Trident, Thor and Typhoon. Both IPv4 & IPv6 is supported.
ASR9K is the first XR platform to support IPv6 QPPB.
Based on interface qppb settings, for the source/Destination prefix, the  IP Precedence and/or QOS group is set in ingress linecard and policy can be attached in egress linecard to act on the modified IP Precedence  and/or QOS group.
1. Purpose:
In short the purpose of QPPB is to allow packet classification based on BGP attributes.
  • IPv4/IPv6 unicast only feature. IPv6 Support only added in 4.2 only in ASR9k platform.
  • Classification based on source or destination IP address
  • Classify on BGP IP prefix / AS path / Community
  • Utilizes Route Policy Language (RPL) for table policies
  • QoS Group ID values 0 – 31 supported
  • IOS XR started supporting in 3.6 in CRS & C12K
  • CRS-1 only supports setting QoS Group ID
  • C12k supports setting IP Precedence and/or QoS Group ID
  • ASR9k supports setting IP precedence and/or QoS Group ID and QOS policy can configured to match on modified IP prec/QOS Group only on egress.
Configuration and verification
In the following example, Router A learns routes from AS 200 and AS 100. QoS policy is applied to all packets that match the defined route maps. Any packets from Router A to AS 200 or AS 100 are sent the appropriate QoS policy.
2. Sample Scenario
The show commands below follow the application and focus of the QPPB on Router "A" and then on the interface towards and connecting with
Router "B".
3. Configuration steps
Configure QPPB to set QoS Group ID
  1. Define Route Policy (routes to match)
  2. Attach Route Policy to BGP instance
  3. Apply QPPB to ingress interface
Configure Egress QoS Service Policy
Example: match on QoS Group ID, set precedence if matched
Route policy configuration
RPL configuration
route-policy qppb
if destination in (60.60.0.0/24) then
   set qos-group 5
elseif source in (192.1.1.2) then
   set qos-group 10
else
   set qos-group 1
endif
pass
end-policy
QPPB ...
•Uses Route Policy Language (RPL)
•IP Destination based on BGP Route
•Source indicates source IP of the BGP Routes
•Also supports AS Path, Community Lists (not shown)
4. Application to BGP and Interface
After the route policy configuration you need to apply it to the table policy to do the marking, right when the routes are being received.
This then also needs to be enforced on the interface with the right QOS configuration to leverage this QPPB setting and act upon that.
BGP
BGP configuration
router bgp 300
bgp router-id 19.19.19.19
address-family ipv4 unicast
table-policy qppb
neighbor 192.1.1.2
remote-as 200
   route-policy pass-all in
   route-policy pass-all out
Interface
Interface level configuration
interface TenG 0/0/0/0
ipv4 address 192.1.1.1 255.255.255.0
ipv4 bgp policy propagation input qos-group destination
keepalive disable
5. Show commands and verification
The following commands give an overview how to verify the QPPB configuration
Using show cef
RP/0/RP0/CPU0:pacifica#show cef 60.60.0.0/24 detail
60.60.0.0/24, version 0, internal 0x40000001 (0x78419634) [1], 0x0 (0x0), 0x0 (0x0)
Prefix Len 24, traffic index 0, precedence routine (0)
QoS Group: 5, IP Precedence: 0
gateway array (0x0) reference count 100, flags 0x80200, source 3,
<snip>
Using show uidb
uIDB is a micro interface descriptor block, it is a data structure that represents the features that are applied to an interface.
In this case this command explains what features are applied to the interface specific to QPPB.
RP/0/RP0/CPU0:pacifica#show uidb data TenG 0/0/0/0 location 0/0/cpu0
<snip>
IPV4 QPPB En             0x1
IPV6 QPPB En             0x1
IPV6 QPPB Dst QOS Grp    0x0
IPV6 QPPB Dst Prec       0x1
IPV6 QPPB Src QOS Grp    0x1
IPV6 QPPB Src Prec       0x0
IPV4 QPPB Dst QOS Grp    0x0
IPV4 QPPB Dst Prec       0x1
IPV4 QPPB Src QOS Grp    0x0
IPV4 QPPB Src Prec       0x0
<snip>
Restrictions and limitations
This to the best of my knowledge
  • In Trident/Typhoon, due to limited space in prefix leaf, all traffic  coming in that interface will undergo QPPB processing (IP Precedence  and/or QOS Group) based on that interface setting. i.e there is no per  prefix level validity checking for IP precedence or QOS group.
TRIDENT
  • The loopback decision is made in TOP Parse, so every packet coming  into the interface, which has the “QOS group” policy configuration with  QPPBenabled will be looped back.
  • Due to the loopback and extra cycles the performance will get impacted.
  • Also the trigger for loopback is the “QOS group” present in  policy, if the user wants to have a policy to act only on the precedence  value modified by qppb, user still needs to have a dummy “QOS group” in  the policy for the loopback to happen to take effect of the new  precedence value.
  • Only QOS format 1 and format 2 is supported in ingress QOS policy.
TYPHOON
  • The loopback decision is made in TOP Parse, so every packet coming  into the interface, which has the “QOS group” policy configuration with  QPPBenabled will be (pipeline)looped back.
  • Due to the pipeline loopback and extra cycles the performance may get impacted.
Debugging QPPB
These debugging examples are not necessarily related to the configuration example above.
Check for QPPB values in route
RP/0/RSP0/CPU0:public-router#show route 120.120.120.120 de
Wed Feb 23 15:20:01.263 UTC
Routing entry for 120.120.120.0/24
Known via "bgp 500", distance 200, metric 0, type internal
Installed Feb 20 23:58:13.096 for 2d15h
Routing Descriptor Blocks
10.1.7.2, from 10.1.7.2
Route metric is 0
Label: None
Tunnel ID: None
Extended communities count: 0
Route version is 0x1 (1)
No local label
IP Precedence: 6
QoS Group ID: 5
Route Priority: RIB_PRIORITY_RECURSIVE (7) SVD Type RIB_SVD_TYPE_LOCAL
No advertising protos.
CEF command output for trident/typhoon
RP/0/RSP0/CPU0:public-router#show cef 120.120.120.120 hardware ingress location 0/0/cPU0 | inc QPPB
QPPBPrec: 6
QPPBQOS Group: 5
CEF Command output in THOR :
Hardware Extended Leaf Data:
fib_leaf_extension_length: 0 interface_receive: 0x0
traffic_index_valid: 0x0 qos_prec_valid: 0x1
qos_group_valid: 0x1 valid_source: 0x0
traffic_index: 0x0 nat_addr: 0x0
reserved: 0x0 qos_precedence: 0x6
qos_group: 0x5 peer_as_number: 0
path_list_ptr: 0x0
connected_intf_id: 0x0 ipsub_session_uidb: 0xffffffff
Path_list:
urpf loose flag: 0x0
List of interfaces:
Chk for QPPBvalue in uIDB
Trident
RP/0/RSP0/CPU0:public-router# show uidb data location 0/0/CPU0 gigabitEthernet 0/0/0/4 ingress | inc QPPB
Wed Feb 23 15:44:33.154 UTC
IPV6 QPPBSrc Lkup 0x0
IPV4 QPPBSrc Prec 0x1
IPV4 QPPBDst Prec 0x0
IPV4 QPPBSrc QOS Grp 0x0
IPV4 QPPBDst QOS Grp 0x0
IPV6 QPPBSrc Prec 0x0
IPV6 QPPBDst Prec 0x1
IPV6 QPPBSrc QOS Grp 0x0
IPV6 QPPBDst QOS Grp 0x0
IPV4 QPPBEn 0x1
IPV6 QPPBEn 0x1
IPV4 QPPBSrc Lkup 0x1
RP/0/RSP0/CPU0:public-router#show run interface gigabitEthernet 0/0/0/4
Wed Feb 23 15:44:52.313 UTC
interface GigabitEthernet0/0/0/4
service-policy output qppp-qos-pol
ipv4 bgp policy propagation input ip-precedence source
ipv4 address 12.12.12.1 255.255.255.0
ipv6 bgp policy propagation input ip-precedence destination
ipv6 address 12:12:12::1/64
Typhoon
RP/0/RSP0/CPU0:public-router#show uidb data location 0/2/cpu0 gigabitEthernet 0/2/0/0 ingress | inc QPPB
Wed Feb 23 15:47:32.436 UTC
IPV4 QPPBSrc Lookup En 0x0
IPV6 QPPBSrc Lookup En 0x1
IPV4 QPPBEn 0x1
IPV6 QPPBEn 0x1
RP/0/RSP0/CPU0:public-router#show uidb data location 0/2/cpu0 gigabitEthernet 0/2/0/0 ing-ex | inc QPPB
Wed Feb 23 15:49:19.118 UTC
IPV6 QPPBSrc QOS Grp 0x1
IPV4 QPPBDst Prec 0x1
IPV4 QPPBSrc Prec 0x0
Thor
(maybe a bit too deep for the general troubleshooting, but since I had this info I thought it might be nice to share in case, for those interested)
Another gotcha to this example below is a Gig interface in a SIP700, while this works, it is officially not supported, it is just for illustrational purposes to show how to feel inside info out to the surface and how to interpret it.
* Flags bit field definitions for BGP_PA and QPPB.
BF_CREATE(bgp_pa_flag_qppb_enabled, 6, 1); // QPPB
BF_CREATE(bgp_pa_flag_src_qos_group, 5, 1); // QPPB
BF_CREATE(bgp_pa_flag_dst_qos_group, 4, 1); // QPPB
BF_CREATE(bgp_pa_flag_src_prec, 3, 1); // QPPB
BF_CREATE(bgp_pa_flag_dst_prec, 2, 1); // QPPB
BF_CREATE(bgp_pa_flag_src, 1, 1); // BPG_PA
BF_CREATE(bgp_pa_flag_dst, 0, 1); // BPG_PA
uidb offset 780 for v4 and 2000 for v6 qppb:
RP/0/RSP0/CPU0:public-router#show controllers pse qfp infrastructure  gigabitEthernet 0/1/1/4 input config raw loc 0/1/CPU0 | inc 780
Wed Feb 23 15:52:21.259 UTC
00000780 00 00 00 48 00 00 00 00
00001780 00 00 00 00 00 00 00 00
00002780 00 00 00 00 89 87 54 00
RP/0/RSP0/CPU0:public-router#show controllers pse qfp infrastructure  gigabitEthernet 0/1/1/4 input config raw loc 0/1/CPU0 | inc 2000
Wed Feb 23 15:53:49.236 UTC
00002000 00 00 00 48 e7 ff 36 f0
RP/0/RSP0/CPU0:public-router#show run interface gigabitEthernet 0/1/1/4
Wed Feb 23 16:04:34.892 UTC
interface GigabitEthernet0/1/1/4
description TGN PORT 7 3
ipv4 address 10.1.7.1 255.255.255.0
ipv6 bgp policy propagation input ip-precedence source
ipv6 address 10:1:7::1/64
ipv6 enable
Check if packets are loopbacking due to ingress QOS policy
(both trident and typhoon)
RP/0/RSP0/CPU0:ASR-PE3#show uidb data location 0/0/cpu0 gigabitEthernet 0/0/0/4.1 ingress | inc QOS
Mon Feb 20 10:57:22.781 UTC
QOS Enable 0x1
QOS Inherit Parent 0x0
QOS ID 0x2004
AFMON QOS ID 0x0
IPV4 QPPBSrc QOS Grp 0x1
QOS grp present in policy 0x1
QOS Format 0x1
Verification of the NP counters, we need to see loopbacks happening (or feedback in PXF or Recirculation in 7600 terminology)
RP/0/RSP0/CPU0:ASR-PE3#show controllers np counters np3 location 0/0/cPU0
Mon Feb 20 11:08:49.262 UTC
Node: 0/0/CPU0:
Show global stats counters for NP3, revision v3
Read 33 non-zero NP counters:
Offset Counter                    FrameValue Rate (pps)
22 PARSE_ENET_RECEIVE_CNT               6861706   45574
23 PARSE_FABRIC_RECEIVE_CNT              6927056   45574
24 PARSE_LOOPBACK_RECEIVE_CNT             6818799   45573
29 MODIFY_FABRIC_TRANSMIT_CNT             6709882   45574
30 MODIFY_ENET_TRANSMIT_CNT              6929272   45574
34 RESOLVE_EGRESS_DROP_CNT                  5     0
38 MODIFY_MCAST_FLD_LOOPBACK_CNT            6818940   45574
RP/0/RSP0/CPU0:ASR-PE3#show uidb data location 0/0/cpu0 gigabitEthernet  0/0/0/4.1 ingress | inc QOSQOS Enable 0x1QOS Inherit Parent 0x0QOS ID  0x2004AFMON QOS ID 0x0IPV4 QPPBSrc QOS Grp 0x1IPV4 QPPBDst QOS Grp 0x0IPV6 QPPBSrc QOS Grp 0x0IPV6 QPPBDst QOS Grp 0x0 QOS grp present in policy 0x1 QOS Format 0x1
Extra Q&A
If the user wants to have a policy to act only on the precedence value modified by qppb, user still needs to have a dummy “QOS group” in the policy for the loopback to happen to take effect of the new precedence value. This requires to configure something like this:
router bgp 1
   table-policy QPPB-PREC
route-policy QPPB-PREC
   if (community matches-any GOLD) then
     set ip-precedence 5
     set qos-group 1 <== dummy qos-group
   endif
end-policy
And at the interface level I should have both ip-precedence and qos-group:
interface TenGigE0/3/0/5
  cdp
  mtu 9194
  ipv4 bgp policy propagation input ip-precedence destination qos-group destination
  ipv4 address 192.1.22.14 255.255.255.254
  load-interval 30
Although in the ingress QoS policy I only match on ip precedence being set by QPPB.
Answer:
You need to have “match on qos group”  in input QOS policy  and not on the route policy.
See the example below
router bgp 1
     set ip-precedence 5
   endif
end-policy
QOS policy will look like this
class-map match-any qos-grp-dummy
  match qos-group 20
  end-class-map
class-map match-any qos-prec
  match precedence 5
  end-class-map
policy-map qppb-input-pref
  class qos-grp-dummy               <--------dummy “qos group”
   police rate percent 20
    exceed-action drop
  class qos-prec
   police rate percent 10
    exceed-action drop
  class class-default
  end-policy-map
And at the interface level you don’t need to have qos-group qppb
  cdp
  mtu 9194
  service-policy input qppb-input-pref
  load-interval 30
Resolution
This section provides the answer or resolution to the problem provided in the "Core Issue" section.
6.
Xander Thuijs CCIE #6775
Principal Engineer IOS-XR; ASR9000, CRS and NCS6K
adrian.taranu
Thank you.
I would have another question please:
The text above shows the following config:
"route-policy qppb
   set qos-group 5
   set qos-group 10
In slide 1/2, one can read:
route-policy qppb
   set qos-group 5
elseif source in (30.30.30.30) then
   set qos-group 10
Can you please tell me which one is correct ?
I would also appreciate if you could put the prefixes/IPs (60.60.0.0/24, 30.30.30.30) on the figure above. Thank you again.
xthuijs
hi adrian,
either example is "fine" really. it merely tries to show the different qos group settings based on classification criteria. the destination in this regard means the prefix against we route, the source refers to a source of the bgp prefix.
the example and shows here use the 192.1.1.2.
xander
Marco Marzetti
Hello Xander,
First of all thank you for the article.
I'm interested in the performance degradation introduced by QPPB.
Are there public figures like those we have for Scaled ACLs (go to page 25)?
xthuijs
hi marco! qppb would be the cost of "regular" QOS marking (when bgp sets a parameter on the packet), and the "regular" cost of doing policing/q'ing regardless of where the set action came from.
QOS is about a 25%-30% performance hit.
The only crux is when you do ingress QOS, when the qos-group is used that qppb is setting. If that is the case, the packet is looped back, so it costs theoretically 40-50% performance, if ALL packets were subject to that.
The reason for this loop is that the ingress match is done early in the pipeline, whereas the qos-group SET is done later on, so if we want to match on the qppb set qos-group, the packet needs a second pass to examine the qos-group now set.
cheers
xander
Marco Marzetti
If i understand you correctly you're referring to ASR9000/XR Feature Order of operation .
Is the loopback operation triggered only if one of the classes in the inbound policy-map explicitly refers to ip precedence or qos-group or IOS-XR is smart enough to understand when it needs to loop?
Thank you so much
xthuijs
correct Marco! and if the npu detects that your qos class-map has a match on qos-group with qppb enabled that sets the qos-group the loop is automatically instantiated.
cheers!!
xander
pawsonmark
Dear Alexander,
Your article is brilliant, thank you.  I have a couple of small questions:
You wrote "In Trident/Typhoon, due to limited space in prefix leaf", what exactly is prefix leaf?
You wrote "The loopback decision is made in TOP Parse", what is TOP Parse?
Beyond IP Presc, can marking and matching be made on DSCP with QPPB?
Thank you,
Mark.
xthuijs
hi mark! thanks! :)
a prefix leaf is the final "end" of a forwarding lookup. In a "standard" 256-256-256-256 lookup model (also known as "mtrie") you can see the lookup as 4 "intersections" on a path to go from start to finish. On each intersection you have 256 choices to make (as opposed to left or right, here you have 256 streets to pick from).
You could simplify this by a left/right only, but that would make the tree lookup longer like: 2-2-2-2-2-2-2-2-2-2 (and possibly longer). the 4 staged model works nice for a lot of /32's, but for summarized routes, lesser choices (2/2/2/2) and possibly a longer tree works better (this because on a summarized route, the last octet or two are all part of that summary route already). Now when we hit the final intersection in the lookup, from where we dont have to make other decisions anymore as this gives us a straight path to the finish line, that is called the leaf.
This leaf holds all kinds of interesting data for the route. For instance the leaf tells us a next hop, egress interface and the like.
Some extra info here
TOP is Task optimized processor. It is not an asic that can only do one thing, it is not a CPU because it as not that flexible. the nice thing of an asic is that it is designed to a single thing, and can't be programmed easily after the die is created. it is very fast though. a cpu having to be very flexible is therefor slow compared to asic. Now what we did in the NPU is that we separated a few "tasks" out over different stages. Each stage is "optimized" to perform a specific task. they are processors as they can be (micro) coded. PARSE/SEARCH/RESOLVE/MODIFY are the stages we carry. Parse is the first stage that deals with packet initial processing. what (sub)if belongs this to, let's interpret the packet and build a key for the tcam based on teh ip header, so later on we can check if an acl or qos class matched etc. More info on stages is here
you can set different things. basically qppb allows the prefix leaf (you know now what that is :) to designate the qos marking for that packet. this marking can be used on ingress (with a recirculation) or on egress to queue, remark or police based on the bgp marked packet on ingress.
cheers!
xander
veasna.cheab
Community Member
Hi Xander,
I have configured QPPB on IOS XE, but in result I noticed only Client upload traffic is matched and policing applied correctly. For the download traffic the policy didn't match and it fall into class class-default instead. Please advise on my configuration and topology as attached.
Best Regards,
Veasna
xthuijs
the config looks correct veasna. could it be that on the downstreAM the community is not matched and therefore the marking is not done causing it to drop to the default class?
check the bgp prefix settings to make sure that the prefix coming form that desired community is set properly.
also for testing you could add an extra commlist to match the other community and add that to the qppb policy with a qos group of 2, than we can see if it is one or both having an issue.
regards
xander
veasna.cheab
Community Member
Hi Xander,
For the downstream side, I do not set any community as I just drop PC client and its setting is just static default route. Please advise if have any technique it could focus on source (I mean upstream side) rather than destination (client PC) for download traffic.
Best Regards,
Veasna
xthuijs
hi vaesna,
hmm yeah the only option I see is that in your route policy that is tied to the table policy for BGP, you could do a if source in <your prefix> then set qos-group whatever
on egress towards the client, you can then use that qos-group to police or whatever.
so the trick being to use "if source in".
cheers!
xander
