Using PowerShell to obtain all PSIRTs for Cisco Nexus
Tim Glen
Summary
I had a need to obtain all the PSIRTs for Cisco Nexus in CSV format similar to how the Cisco IOS Software Checker performs.
Steps
1. Follow this document to authenticate.   Be sure to take note of your access_token,  you will need it.
NOTE: Remember the access_token is ONLY valid for one hour after you obtained it.
2. Run the code below to obtain all Nexus PSIRTs.
# Clear all Used Variables
$token_type=''
$access_token=''
$auth_header=''
$url=''
$headers=''
$response=''
# Create the Headers and the WebRequest
$token_type=$auth_response.token_type.ToString()
$access_token=$auth_response.access_token.ToString()
$auth_header=$token_type + ' ' + $access_token
$headers=@{Accept='application/xml';Authorization=$auth_header}
$url='https://api.cisco.com/security/advisories/cvrf/product?product=nexus'
# Send the Query
$response=Invoke-RestMethod -URI $url -Method Get -Header $headers
#Write the Output
$response.advisories.advisory | Export-Csv -Path c:\temp\nexus-psirts.csv
3. Run the code below to obtain all NX-OS PSIRTs. There will be duplicates from Step 2 but there will be new entries too.
$token_type=''
$access_token=''
$auth_header=''
$url=''
$headers=''
$response=''
$url='https://api.cisco.com/security/advisories/cvrf/product?product=nx-os'
# Send the Query
#Write the Output
$response.advisories.advisory | Export-Csv -Path c:\temp\nxos-psirts.csv
4.  In the tool of your choice merge the two CSV files and delete the duplicate lines.
Output
One thing I noticed is that in the CSV there are several fields that have no usable value eg. bugIDs, ipsSignatures, cves, etc, I just hide \ delete these. I'll wrap text on the Summary column & vertically center all the columns.
Hope this helps.    Please rate and comment!
lbandlav
Thanks! This worked for NXOS, but is there a way, using which i can still filter based on NXOS and protocol SSH..etc?
