Camera Admin
Twiles
Community Member
Is there a way to give a user full access (not just View & Export) to cameras with in a network without giving them admin access to the switches and wireless?
MacuserJim
Level 7
Level 7
You would need to put the cameras on their own network in the dashboard and give them access to that network.
MacuserJim
Level 7
Level 7
Correct, if you add a camera only admin, they only have the "Cameras" menu locale and they have access to view and/or export, do motion search, etc. They only get the Video and Analytics tabs, but no access to the settings or network or other tabs. As @MacuserJim mentioned, you could place the cameras in a separate Dashboard network, and then under Organization > Administrators create admins with full access to just the camera network and no org-wide access.
