Hello, I'm working on a montage where I need to create a GRE IPsec tunnel between routers. But when I'm, trying to execute some command, the router is not going into the dedicated configuration option. For example, when I'm executing the following co...
view more
Customer licenses are managed in a Smart Account at software.cisco.com.
Portal access required cisco.com portal User create Cisco User (CCO ID)
The Smart Account name will be the customer email domain name.
Example: John.doe@website.com Smart Account name...
view more
I am trying to downgrade ASR9006 from 7.1.2 to 7.0.2, but got the following error
RP/0/RSP0/CPU0:ASR9010_2#install activate id 12Mon Jul 4 08:37:00.110 UTCInstall prepare operation 8 for Host VM is waiting to be activated. At this point, valid inst...
view more
Connectivity Issue to First Node. Verify that the first node is powered on, the network connection is up and the security password on this node and the first node are the same. You might be also seeing this message due to the installation of the free comm...
view more
Hello to the whole community and thank you very much in advance.I would like to ask about Smart account licensing First. When licensing a device in the cisco portal as a switch or router and if the license expires, what would be the limitations of de...
view more
