Showing results forĀ
Search instead forĀ
Did you mean:Ā
Border node replacement in SDA solution
ali ezzat
Frequent Visitor
Frequent Visitor
Dears,
I have border and control node  ( one box) and it is down due to power problem and need to replace with RMA and after getting the new device how to replace it at the DNA as a border and control node ?
is there is any automation process i must follow like replacement ? ( but i think this option not compatible with border only edges)
what i can  do to keep my configuration the same on edges ( ptp ips and neighbors status )?
7 Replies 7
kristoff1
Level 2
Level 2
Hi Ali,
I would remove the faulty border/control plane node. Start the LAN automation process with the second border/control plane node as seed device. After the lan automation is completed you can configure the border/control plane role on the new device.
After this you need to do the manual or the automatic border handoff. If you use automatic border handoff you will need to reconfigure your Fusion device to with the new subnets.
Kind regards,
Kristoff
What about ptp ips between old border and edges , not need to change edges configuration
It seems DNA-C is also supporting the RMA workflow for SDA devices in version 1.3.3.x
You can find the user guide on following link:
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/1-3-3-0/user_guide/b_cisco_dna_center_ug_1_3_3_0/b_cisco_dna_center_ug_1_3_2_0_chapter_011.html?bookSearch=true#id_115372
kind regards,
Kristoff
Thanks for your support
but I already read this doc but nothing about border they talking about edges
Ali,
In that document it states:
"RMA supports replacement of all switches, routers, SDA devices, and devices that are provisioned by LAN automation, except stacked switches, Nexus switches, access points, devices with dual supervisor engines, and wireless controllers.
Note
For SDA devices, you must manually add the replacement device to Cisco DNA Center, because SDA networks do not have DHCP servers and the device cannot be added through PnP.
I would think that Borders fall under "all...SDA devices". This document is for 1.3.3.x, so you will need to be on that version. You said you are on 1.3.5, but there is no 1.3.5. There is 1.3.0.5, 1.3.1.5 and 1.3.3.5.
Cheers,
Scott Hodgdon
Senior Technical Marketing Engineer
Enterprise Networking and Cloud Group
Scott Hodgdon
Ali,
What version of DNA Center do you have ?
Cheers,
Scott Hodgdon
Dear scott,
dna version 1.3.5 and can upgrade to the latest
