C9300 as both distribution and edge
pc5301
Can i use a c9300 (16.12.4) as both a distribution switch (the fiber ports) and edge switch (copper)?
willwetherman
Hi @pc5301 ,
Yes, it is supported to use a Cat 9300 to act as both a distribution/intermediate node and as a fabric edge node. I have a few SD-Access deployments with fabric edge nodes that are connected to other edge nodes without any issues. Please see the following community posts that discuss this in further detail
https://community.cisco.com/t5/software-defined-access-sd/intermediate-edge-node/td-p/4033584
https://community.cisco.com/t5/cisco-digital-network/sda-edge-node-behind-edge-node/td-p/3750493
Hope that this helps
willwetherman
Hi @pc5301 ,
Thank you for your time!
