SDA Wireless Connectivity Issues
SEM68046
Visitor
We are running wired & wireless SDA at one of our facilities. Seems to work fairly well. In the last couple of months, we've been encountering some weird wireless connectivity issues. At completely random times, wireless appears to drop in random areas, impacting groups of clients for 2-5 min at a time. The APs do not appear to go offline. We've used Thousand Eyes to look at agents and it says unhealthy gateway. We've upgraded all of the switches and 9800 WLC to 17.15.4.d. We are not seeing anything in the logs. We've worked with Cisco TAC and setup multiple captures but TAC is not seeing anything. It is very intermittent and very hard to actually capture int he act. We are not seeing this type of issue on any other Traditional site, just at our SDA sight. We have a few SSIDs, but not too many, very good coverage with minimal overlap. We removed DFS channels and tuned down to 20mhz channels for a Vocera applicatin requirement. Has anyone seen anything like this at all and are there any recommendations.
10 Replies 10
aleabrahao
Meraki Community All-Star
This is quite complicated because there are several possibilities.
If LISP mappings or RLOC connectivity fluctuate, clients may "lose network" even if the RF signal is working correctly.
In this case, check the following commands on the Fabric Edge:
show lisp session
show lisp eid-table vrf <vrf>
show lisp instance-id detail
Then look for Map-Server timeouts, RLOC flaps, and Registration drops.
I am not a Cisco employee. My suggestions are based on documentation of Cisco, best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
We are running AP9164 aps, but I can check it
SEM68046
Visitor
Cisco is suspecting bug: CSCwt19011. I am planning to install 17.15.4d APSP this week to possibly resolve this issue.
CoryMatz
Frequent Visitor
Frequent Visitor
We have the same issue, specifically with voceras. It was noticed when roaming from one access point on a switch to another access point on a different switch. We have been told a new release 17.15.5 APSP 2 will address this issue.
SEM68046
Visitor
Interesting. The devices I'm working with are stationary wireless desktops and laptops mostly, but we do have some "mysterious" issues with choppy vocera audio and hit and miss connectivity with EEG, EKGs, Ultrasounds and Xray devices with no network changes and excellent coverage. 17.15.4d APSP did nothing to resolve the very sporadic wireless issue. I may preset that version to TAC to get their thoughts. Thanks
Have you tried 17.15.5 as the bug seems to be fixed in SMU APSP?
SEM68046
Visitor
Interesting. No we've not upgraded to that version yet. We were seeing a ton of SSDP traffic and just blocked all of that. I'm still capturing logs but I posted this to my TAC engineer to see if maybe we are running into that as well
SEM68046
Visitor
I stand corrected. We did not update to that version but did put on a patch that was to have fixed that issue and it did not resolve the issue we are currently seeing.
Hello
just a quick Q please - did u hit issue w/ 17.15.4b or which exactly SW?
thank u
SEM68046
Visitor
We were actually a bit farther back when we hit it. We were on 17.09.05 when we hit it. We then upgraded to 17.16.4d and then installed an AP hotfix, which is included in 17.15, but this did not resolve our issue and ultimately was not what was causing our issues. We just disabled ALL SSDP traffic from windows clients and am waiting to see if the issue resurfaces. This is a default service in windows and was generating about 200 mb of traffic per minute.
