Greetings,
When using the new 4 Gbps cards, you don't loose the ability to use the other ports in the port group when the port becomes an E/TE port. I would like to know if you need to dedicate the 4 Gbps speed on the port when it becomes an E port. I was told today that you can set 4 Gbps and leave it in shared mode. I was a bit surprised at this as I thought the E port had to be dedicated.
I will find out tomorrow if that is possible but I would like the gospel truth on it. I think you need to dedicate it.
Stephen
