5428 and MSA 1000
kaned
Im having an performance issue, if I use the HP PAT test im getting around 3 MBS - 6 MBS, im thinking i should be getting an higher throughput with this setup
Heres my setup and config
DL380 G2
I have all the latest firmware for the dl380 and have had HP verify the config and diag on the msa via array diag utility
EMULEX HBA
Cisco storage router
ive changed gbics and cables
ver 3.41-k9
config on 5428 is attached
Msa 1000
latest firmware verified by hp array diag verified by hp
If you have any suggestions id really apreciate your comments and or suggestions
also can anyone with a similar setup tell me what they are getting with the HP pat test
Thannk You
Not applicable
Check if you are getting any errors on any of the interfaces. In some cases if there is a hardware problem with the interfaces the throughput comes down. Has the throughput ever crossed 3 Mb. If so was any changes done after which the throughput has dropped.
