9509 FCP Mainframe Connection
thomas.paul
Both our IBM support engineer and our HDS support engineer have suggested that the IBM Z10 has to convert from ficon to FC and therefore may require a "Mainframe Pkg" license on the Cisco 9509 switch.   Would you have information to support this?
The Cisco 9509 switch  is running SanOS 3.3.1(c).  I am attempting to zone a new host (IBM Z10 mainframe) to access storage on  my  HDS USPV storage subsystem.  I have a good fibre link at 4gb. The Z10 can see the WWN of the HDS.  The issue is that the Z10 server is presenting to the switch as a target (disk) instead of an initiator (host).  As a result, despite zoning these devices together, the HDS does not recognize the WWN of the Z10 when I attempt to provision storage in an HDS port/host group.
Mainframe FCP definitions, I hope that the following info helps
Switch inventory including components and version numbers.
SAN switch port 8-35 is the Z10 (Mainframe).  The WWN of this device is seen however it shows as a target instead of an initiator
Despite proper zoning, the HDS USPV does not see the WWN of the Z10 on its port 1A.
Below is th USPV  (SAN Disk - Hitachi)  port list, the direct connection was made to port 3F:
#!Version 05_00_00
Basic Information
[Port]
#SLPR
Port Name
Type
Host Speed
Addr.(LoopID)
Fabric
Connection
Attribute
WWN
00:SLPR0
CL1-A
Fibre
Auto
EF (0)
Enable
P-to-P
Target
50060E800543B000
00:SLPR0
CL3-A
Fibre
Auto
E8 (1)
Enable
P-to-P
Target
50060E800543B020
00:SLPR0
CL5-A
Fibre
Auto
E4 (2)
Enable
P-to-P
Target
50060E800543B040
00:SLPR0
CL7-A
Fibre
Auto
E8 (1)
Disable
FC-AL
Target
50060E800543B060
00:SLPR0
CL1-B
Fibre
Auto
E1 (4)
Disable
FC-AL
Target
50060E800543B001
00:SLPR0
CL3-B
Fibre
Auto
E0 (5)
Enable
P-to-P
External
50060E800543B021
00:SLPR0
CL5-B
Fibre
Auto
E8 (1)
Enable
P-to-P
Target
50060E800543B041
00:SLPR0
CL7-B
Fibre
Auto
DA (7)
Enable
P-to-P
External
50060E800543B061
00:SLPR0
CL1-E
Fibre
1 Gbps
E8 (1)
Disable
FC-AL
Target
50060E800543B004
00:SLPR0
CL3-E
Fibre
1 Gbps
E8 (1)
Disable
FC-AL
Target
50060E800543B024
00:SLPR0
CL5-E
Fibre
Auto
E8 (1)
Enable
P-to-P
Target
50060E800543B044
00:SLPR0
CL7-E
Fibre
1 Gbps
E8 (1)
Disable
FC-AL
Target
50060E800543B064
00:SLPR0
CL1-F
Fibre
Auto
C9 (20)
Disable
FC-AL
Target
50060E800543B005
00:SLPR0
CL3-F
Fibre
Auto
E8 (1)
Disable
FC-AL
Target
50060E800543B025
00:SLPR0
CL5-F
Fibre
Auto
E8 (1)
Enable
P-to-P
Target
50060E800543B045
00:SLPR0
CL7-F
Fibre
Auto
C5 (23)
Enable
P-to-P
Target
50060E800543B065
00:SLPR0
CL1-G
Fibre
Auto
98 (48)
Enable
P-to-P
Initiator
50060E800543B006
00:SLPR0
CL3-G
Fibre
Auto
97 (49)
Disable
FC-AL
Initiator
50060E800543B026
00:SLPR0
CL1-H
Fibre
Auto
88 (52)
Enable
P-to-P
RCU Target
50060E800543B007
00:SLPR0
CL3-H
Fibre
Auto
84 (53)
Disable
FC-AL
RCU Target
50060E800543B027
00:SLPR0
CL2-A
Fibre
Auto
D9 (8)
Enable
P-to-P
Target
50060E800543B010
00:SLPR0
CL4-A
Fibre
Auto
D6 (9)
Enable
P-to-P
Target
50060E800543B030
00:SLPR0
CL6-A
Fibre
Auto
D5 (10)
Enable
P-to-P
Target
50060E800543B050
00:SLPR0
CL8-A
Fibre
Auto
E8 (1)
Disable
FC-AL
Target
50060E800543B070
00:SLPR0
CL2-B
Fibre
Auto
E8 (1)
Disable
FC-AL
Target
50060E800543B011
00:SLPR0
CL4-B
Fibre
Auto
D2 (13)
Enable
P-to-P
External
50060E800543B031
00:SLPR0
CL6-B
Fibre
Auto
E8 (1)
Enable
P-to-P
Target
50060E800543B051
00:SLPR0
CL8-B
Fibre
Auto
CE (15)
Enable
P-to-P
External
50060E800543B071
00:SLPR0
CL2-E
Fibre
1 Gbps
E8 (1)
Disable
FC-AL
Target
50060E800543B014
00:SLPR0
CL4-E
Fibre
1 Gbps
E8 (1)
Disable
FC-AL
Target
50060E800543B034
00:SLPR0
CL6-E
Fibre
Auto
E8 (1)
Enable
P-to-P
Target
50060E800543B054
00:SLPR0
CL8-E
Fibre
Auto
E8 (1)
Disable
FC-AL
Target
50060E800543B074
00:SLPR0
CL2-F
Fibre
Auto
B6 (28)
Disable
FC-AL
Target
50060E800543B015
00:SLPR0
CL4-F
Fibre
Auto
B5 (29)
Disable
FC-AL
Target
50060E800543B035
00:SLPR0
CL6-F
Fibre
Auto
E8 (1)
Enable
P-to-P
Target
50060E800543B055
00:SLPR0
CL8-F
Fibre
Auto
B3 (31)
Enable
P-to-P
Target
50060E800543B075
00:SLPR0
CL2-G
Fibre
Auto
80 (56)
Enable
P-to-P
Initiator
50060E800543B016
00:SLPR0
CL4-G
Fibre
Auto
7C (57)
Enable
P-to-P
Initiator
50060E800543B036
00:SLPR0
CL2-H
Fibre
Auto
76 (60)
Enable
P-to-P
RCU Target
50060E800543B017
00:SLPR0
CL4-H
Fibre
Auto
75 (61)
Enable
P-to-P
RCU Target
50060E800543B037
Your help is highly appreciated.
Warm Regards,
Tom Paul
Interactive Data
thomas.paul@interactivedata.com
1-781-687-8146
kenk
Hi Tom,
Very interesting problem you're reporting.
In general, IBM Mainframes use FICON to talk to their Storage.  And, in general, the Mainframe license is
needed for the FICON feature on MDS switches.
If your Z10 is really using FC (no FICON) to talk to storage, then it would be best to work with the
appropriate IBM support team to determine why it is registering itself as a Target (instead of Initiator).
I did do a quick look in the TAC SR database to see if we have any other similar issues but I didn't find any.
Ken
Thank you, Ken.
I did contact IBM and they don't have a clue either. I contacted Hitachi and their response is switch configuration (CISCO 9509) is ok. So, they plan to take a dump of their storagedevices - which doesn't make sense. But, your response points is very interesting. If you are interested in discussing further, I'll forward the data.
Happy Holidays!
Warm Regards,
Tom
Tom,
I agree with Ken, you got a interesting issue. Few questions for you?
1) to test, have you tried using FICON feature instead of FCP? You can enable FICON trial period (good for 120 days).
2) setup FICON vsan, zone and test to see if any different result.
3) is there any settings on Z10 to change HBA to discover as initiator, instead of target.
Nisar
Hi Ken,
Thank you very much for the reply. The mainframe IOCP is generated as 'FCP' connection to the ports below.
The switch config is given below:
They are both zoned correctly and in the active zoneset.
zone name Z10-SANA vsan 101
  • fcid 0xa20129
  • fcid 0xa20170
fc3/24 101 0xa20129 50:06:0e:80:05:43:b0:00 50:06:0e:80:05:43:b0:00
fc8/35 101 0xa20170 50:05:07:64:01:e2:a1:74 50:05:07:64:00:cd:1f:d2
The IBM Z10 HBA does not register as target or initiator. It appears that only the Fabric Manager assumes it is a target and very likely based on it’s WWN. The fc4-type registration should not be a factor.
