Can the same pair of Fabric Interconnect be shared for both UCS Blades and HyperFlex?
SIMMN
I have a customer asking to quote for some hx220m4 boxes but they do not want to buy another pair of the FIs. They want to just use their existing FIs which are currently used for the UCS chassis. I never done the shared FI for UCS and HyperFlex...Is it supported by Cisco? If so, would there be any risk?
Also, I read somewhere on cisco.com that UCS chassis is supported to be added to FIs of an existing hyperflex cluster. Is it still true?
Kirk J
Greetings.
That is a loaded question ;)
Please see https://www.cisco.com/c/en/us/td/docs/hyperconverged_systems/HyperFlex_HX_DataPlatformSoftware/TechNotes/b_Adding_HX_to_Existing_UCS-FI_Domain.html
The answer is "maybe", depending on requirements for existing blades, the requirements for HX, how large a HX environment you think you will grow to, etc
As the above referenced article mentions, you will want to have the customer open a TAC case to review the existing config, go through the HX checklist, and potential caveats.
This is a scenario where, if done incorrectly, will end up with an under-performing HX or overall UCSM environment that is out of compliance/unsupported.
Kirk...
Kirk J
Greetings.
Kirk...
Thanks! Good information.
