02-05-2003 07:11 AM
I was doing some research about the emergence of SoIP networks. Currently Nishan makes a box that does FC,iSCSI, IP all in one box. So basically what you can do is have FC to your servers and to your storage with IP run by 6509's in between so that you can connect to remote storage and it also gives you the ability to run a standards based protocol which FC has accomplished yet.
Question is this. Is this the capability that has been designed into the Cisco 9000 series?
02-05-2003 10:04 AM
Yes, and much more- Has the concepts of vsans , just like vlans, Web enabled configuration, good troubleshooting resources etc.. Cisco MDS 9506 series switches are director class switches.. There is also mds9200, only 2 slots switch..
Here are more information
http://cco/en/US/products/hw/ps4159/ps4358/prod_technical_details.html
02-05-2003 10:06 AM
