cisco m9100 MDS cpu state discrepencies
buzzy00000
Hi.
I have weird issues with my m9100 MDS's cpu. After CISCOWorks complains that thoses equipement were peaking at 100% every minutes or so, I went on the equipements and try'd a few "show system ressources". Here is the result (remark the cpu states in bold);
FC-BLAMTL04-1# show system resources
Load average:   1 minute: 0.02   5 minutes: 0.14   15 minutes: 0.16
Processes   :   182 total, 1 running
CPU states  :   25.0% user,   75.0% kernel,   0.0% idle
Memory usage:    516136K total,    450816K used,     65320K free
                   6340K buffers,  247552K cache
Load average:   1 minute: 0.02   5 minutes: 0.13   15 minutes: 0.16
CPU states  :   50.0% user,   50.0% kernel,   0.0% idle
CPU states  :   340282346638528859811704183484516925440.0% user,   340282346638528859811704183484516925440.0% kernel,   340282346638528859811704183484516925440.0% idle
Memory usage:    516136K total,    450624K used,     65512K free
Load average:   1 minute: 0.01   5 minutes: 0.12   15 minutes: 0.16
CPU states  :   33.3% user,   66.7% kernel,   0.0% idle
It appear, sometime, for an unknown reason, CPU peaks to a weird % number (I thought a % couldn't get higher than 100).
Also, trying a "show process" (to get the running processes) command dosen't work. I am only able to "show processes"
Did someone experience same kind of discrepencies? I am running m9100-s2ek9-mz.4.1.1b.bin image.
Thank you.
Filiph Westman
Seen a lot of  incorrect CPU utilization values due to bug CSCte81951. Note the new spelling of the command to see the cpu history etc.
From bug info:
"show system resources" shows high cpu usage even when there is not much activity on the switch.
In the specific case reported the cpu util (user+kernel) was always 100%.
No workarounds. Use "show processes cpu history" or "show processes cpu" for
cpu util. Fixed in 4.2(4) and 5.0(1a).
