11-14-2017 12:03 AM - edited 03-01-2019 06:16 AM
Hi Friends
I need a help from you guys.
We have Cisco MDS9124 Failed Switch connected in fabric, We want to replace with other Cisco MDS 9124 which is healthier but in loader mode when we are connecting through serial.
Now I want to replace the failed switch with healthier switch.
For that I need to configure that healthier switch to normal from loader mode.
As well please suggest if we add this switch after configuring name, ip and etc. into the fabric the zoning configurations will automatically replicated from the principal switch/fabric or we need to do it manually.
11-14-2017 03:18 AM
Do you have a configuration backup of the failed switch ? if not, good luck ! you start from scratch.
Does the replacement switch boot standalone ? you would need to do a erase all.
11-29-2017 11:15 PM
Yes we have backup of failed switch but we don"t have ftp server to restore config. Is there nay other option to restore?
11-29-2017 11:17 PM
12-12-2017 05:48 PM
