Cisco MDS 9148 port aggregation bandwidth output via port channeling.
Ashish Kumar
Hi guys,
I want to test the aggregation bandwidth on the MDS 9148, How can we do it?
I tried to do it via below command:
In Config mode:
feature fport-channel-trunk
Feature npv
Switch A-
 interface port-channel 10
   channel mode active
   switchport mode NP
   switchport trunk allowed vsan 1
   switchport rate-mode dedicated
   switchport trunk mode on
 interface fc1/1-2
   switchport mode NP
   port-license acquire
   channel-group 10 force
   no shutdown
But my port is not showing me bundled speed, as expected 16 Gbps, because one having 8 Gbps bandwidth.
Ashish
Walter Dey
Are you connecting this MDS 9148 (NPV mode) to another switch, running in NPIV mode ?
Can you please post output of "show interface fc 1/1 - 2" and port-channel 10....
hi walter,
We want to test port aggregation. So we are trying to port channeling with 4 port and will show the client 4x8 Gbps =32Gbps output.
Following this document.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/5_2/configuration/guides/int/nx-os/cli_interfaces/pc.html#97250
Will share you soon port details.
Ashish
Hi Ashish
I hope we talk about the same ? there is E PortChannels and F and TF PortChannels !
We talk about F and TF PortChannels !
Note If a Cisco MDS 9124 or 9134 switch is used as a core switch, only a nontrunking F PortChannel is supported. Trunking is not supported on this platform when NPIV enabled.
That's why I asked you what kind of switch is running NPIV ?
Walter.
Hi Walter,
Thanks for your support.
I done it today after port channeling with 8 port with single port-channel.
and we get the output 64Gbps as below output.
San(config-if)# sh inter po 10
port-channel 10 is trunking
    Hardware is Fibre Channel
    Port WWN is 24:0a:00:2a:6a:d1:18:58
    Admin port mode is auto, trunk mode is on
    snmp link state traps are enabled
    Port mode is TE
    Port vsan is 1
    Speed is 64 Gbps
    Trunk vsans (admin allowed and active) (1-2)
    Trunk vsans (up)                       (1)
    Trunk vsans (isolated)                 (2)
    Trunk vsans (initializing)             ()
    5 minutes input rate 3168 bits/sec, 396 bytes/sec, 1 frames/sec
    5 minutes output rate 2728 bits/sec, 341 bytes/sec, 1 frames/sec
      4056 frames input, 345444 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      4170 frames output, 263456 bytes
      37 input OLS, 50 LRR, 0 NOS, 120 loop inits
      40 output OLS, 14 LRR, 16 NOS, 32 loop inits
    Member[1] : fc1/25
    Member[2] : fc1/26
    Member[3] : fc1/27
    Member[4] : fc1/28
    Member[5] : fc1/29
    Member[6] : fc1/30
    Member[7] : fc1/31
    Member[8] : fc1/32
San(config-if)# sh int port-channel 10 brie
Interface             Vsan  Admin  Status        Oper  Oper    IP
                            Trunk                Mode  Speed   Address
                            Mode                       (Gbps)
port-channel 10       1     on     trunking       TE   64      --
Ashish
