Cisco MDS Fabric switch selection
miank
Hi Fellows,
I have required Cisco MDS fabric switch for DC with below requirements... anyone can suggest better model including below features :-
support for enterprise class storage solutions e.g. EMC, HP, Hitachi etc.
 4/8/16Gig fiber channel
64 x fiber channel ports
4 x copper channel ports
FC, FCIP, FCOE, iSCSI supported protocols
support for block, file/object based storage solution
software defined storage support for  Ceph, VMware Virtual Volumes
must be able to support integration with heterogeneous fabric switch environment & backup solutions i.e open source.
virtualization and cloud computing (VMware vRealize, OpenStack) support
different multi-pathing solution e.g. third party OR native OS based
Walter Dey
9300 doesn't support FCoE nor FCIP
http://www.cisco.com/c/en/us/products/collateral/storage-networking/mds-9396s-16g-multilayer-fabric-switch/datasheet-c78-734525.html
9700 doesn't support FCIP, but otherwise would fullfill all your requirements
http://www.cisco.com/c/en/us/products/storage-networking/mds-9700-series-multilayer-directors/models-comparison.html
The 9250i supports all your requirements
http://www.cisco.com/c/en/us/products/storage-networking/mds-9200-series-multiservice-switches/models-comparison.html
The 9205i only has the following ports...
20 x 2/4/8/16-Gbps FC
8 x 10-Gbps FCoE
2 x 10 GE
You need at least 64 Fibre Channel ports.
Why FCIP are you trying to extended the SAN between Data Centers?
