Cisco Nexus 5548UP connect to dual NetApp controllers using FCOE
warferik5
Here is my setup, I have two 5548UP's connected via VPC peer link. I am tring to use VPC to connect to a NetApp with dual 10gb ports using FCOE, with each 5548 getting one of the connections.
I then want to use VPC to connect to a dell server that has dual 10gb ports using FCOE as well with each 5548 getting a connection. I am new to FCOE, any help would be appreciated. I am getting confused in the configuration for both. Thanks
vsathiam
Erik,
Can you check the deployment guides from links pasted below -
http://www.cisco.com/en/US/solutions/ns340/ns414/ns742/ns743/ns1050/landing_flexpod.html
http://www.cisco.com/en/US/docs/solutions/SBA/February2013/Cisco_SBA_DC_NetAppStorageDeploymentGuide-Feb2013.pdf
Head to the Nexus 5k section and check how FCoE is configured, how vPC is configured..
Once you tackle 5k, depending on your Environment (from Netapp perspective), check how to create Interface groups.
