Command Accounting on MDS
kendo.igor
Is Command Accounting available on MDS 9216.
We use Command Accounting on our Catalyst Switches to capture the commands entered on the switches for auditing purposes. Entered commands on the Catalyst switches are captured on Cisco ACS server and we can see who has done what under the "TACACS Administration" logs of ACS. Is this feature available on MDS switches as well.
dahersey
Command accounting is available on the MDS platform as well. This could utilize the same TACACS+ backend you have for your Catalyst network.
You also will have very detailed control over who has access to what commands with Roles Based Access Control.
Dan
