Configuring port FC and FCoe in Nexus 2348UPQ
mhuaynate
Hi friend:
I am trying  to configuring FC and FCoE port in nexus 2348UPQ wich is in fex mode, according to the data shet the nexus 2k support this configuring. In Ethernet mode work fine, but when configuring in FC and FCoE does not work. I am configuring in both Nexus 5K vpc peer, where is attached the nexus 2k.
NX-CD-G16-01A# show  fex
  FEX         FEX           FEX              FEX              Fex
Number    Description      State            Model            Serial
105        FEX0105                Online   N2K-C2348UPQ-10GE   FOC1849R13M
106        FEX0106                Online   N2K-C2348UPQ-10GE   FOC1849R13A
107        FEX0107                Online   N2K-C2348UPQ-10GE   FOC1849R16R
109        FEX0109                Online   N2K-C2348UPQ-10GE   FOC1849R139
110        FEX0110                Online   N2K-C2348UPQ-10GE   FOC1849R13C
NX-CD-G16-01A#
interface Ethernet105/1/41
  speed 1000
interface Ethernet105/1/42
  speed 1000
interface Ethernet105/1/43
  speed 1000
interface Ethernet105/1/44
  speed 1000
interface Ethernet105/1/45
  speed 1000
interface Ethernet105/1/46
  speed 1000
interface Ethernet105/1/47
  speed 1000
interface Ethernet105/1/48
  speed 1000
Convert port fex interface Ethernet 105/1/x in FC port does not work
NX-CD-G16-01A(config)# slot 1
NX-CD-G16-01A(config-slot)# port 105/1-40-48 ?
% Invalid command at '^' marker.
NX-CD-G16-01A(config)# slot 105
NX-CD-G16-01A(config-slot)# port 44-48 type fc
ERROR: Invalid slot specified
Convert port fex interface Ethernet 105/1/x in FCoE port does not work
NX-CD-G16-01A(config)# interface vfc 3
NX-CD-G16-01A(config-if)# bind interface ethernet 105/1/48
ERROR: fcoe_mgr: Cannot bind the VFC as the Fex not fcoe configured (err_id 0x4207005B)
NX-CD-G16-01A# show  feature | inc enabled
fcoe                  1         enabled
fex                   1         enabled
interface-vlan        1         enabled
lacp                  1         enabled
lldp                  1         enabled
sshServer             1         enabled
telnetServer          1         enabled
vpc                   1         enabled
I found this page from Cisco. I attached the topology.
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-2000-series-fabric-extenders/datasheet-c78-731663.html
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/layer2/513_n1_1/b_Cisco_n5k_layer2_config_gd_rel_513_N1_1/b_Cisco_n5k_layer2_config_gd_rel_513_N1_1_chapter_01010.html
Thank.
Best regard,
Marco.
jihicks
Hi Marco,
FC support for the 2348UPQ is not available yet.
I do not have a date other than it is planned for this calendar year.
Best regards,
Jim
6 Replies 6
jihicks
Hi Marco,
Best regards,
Jim
Jim:
Thank so much.
Marco
Hi Chris,
Support for FC over 2348UPQ is tentatively scheduled for the first half of next year.
Best regards,
Jim
Many thanks Jim,
That is very disappointing as it is a lot further away than we were initially told.
Maybe you could tell me if it is possible to extend the VSANs over multiple Nexus switches to allow us to place the storage on our FC capable core switches?  Please see the attached diagram to help with my feeble explanation.
Many thanks
Chris
Hi Chris,
Thank you very much for the information.
Best regards,
philippe
Hi Jim,
Is there any update on when this will be available?  We bought 2348UPQ after being told they would support FC in the near future.  We are now ready to configure our new equipment but concerned this hasn't been made available yet.
Chris
