Content Engine NM ACNS/network access
kdog_1914
After searching Google and Cisco, here's my setup...
2851 Router running 15.1T
CE-NM-BP-80G-K9 in slot 1/0
Bridge group 1 for LAN and Wireless WIC.
Goal:  Either add the external CE interface to the LAN on the bridge group or use WCCP to cache traffic through the internal interface.
I was able to access ACNS once, but I'm completely new to the design and it was only for testing with the IP scheme.  I reset the config, reloaded the router and now I can't access ACNS via the web gui nor can I access the network from the CE (ping or ftp).
Interface ContentEngine 1/0 Config:
     ip address 10.0.0.1 255.255.255.0
     Service Module ip address 10.0.0.2 255.255.255.0
     Service Module external ip address 10.0.1.1 255.255.255.0
     Service Module ip default gateway 10.0.0.1
Interface BVI1
     ip address 192.168.2.1 255.255.255.0
     using dhcp etc
Service module config:
CE#sh run
! ACNS version 5.5.3
hostname CE
http proxy incoming 80 8080
ip domain-name mydomain.com
interface FastEthernet external
exit
interface FastEthernet internal
exit
wmt evaluate
wmt accept-license-agreement
wmt enable
ip name-server 8.8.8.8
ip name-server 192.168.2.1
wccp router-list 1 192.168.2.1
wccp web-cache router-list-num 1
wccp reverse-proxy router-list-num 1
wccp wmt router-list-num 1
wccp version 2
username admin password 1 xxx
username admin privilege 15
username xxxx password 1 xxx uid 2001
username xxxx privilege 15
authentication login local enable primary
authentication configuration local enable primary
cdm ip 192.168.2.1
! End of ACNS configuration
Here's what I get when attempting to ping:
CE#ping 192.168.2.1
connect: Network is unreachable
CE#ping 10.0.0.1
CE#ping 10.0.1.1
And from the LAN:
seth@Sony:~$ ping 192.168.2.1
PING 192.168.2.1 (192.168.2.1) 56(84) bytes of data.
64 bytes from 192.168.2.1: icmp_req=1 ttl=255 time=1.79 ms
^C
--- 192.168.2.1 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 1.799/1.799/1.799/0.000 ms
seth@Sony:~$ ping 10.0.0.1
PING 10.0.0.1 (10.0.0.1) 56(84) bytes of data.
64 bytes from 10.0.0.1: icmp_req=1 ttl=255 time=1.39 ms
64 bytes from 10.0.0.1: icmp_req=2 ttl=255 time=1.93 ms
^C
--- 10.0.0.1 ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1001ms
rtt min/avg/max/mdev = 1.396/1.666/1.936/0.270 ms
seth@Sony:~$ ping 10.0.0.2
PING 10.0.0.2 (10.0.0.2) 56(84) bytes of data.
^C
--- 10.0.0.2 ping statistics ---
2 packets transmitted, 0 received, 100% packet loss, time 1006ms
seth@Sony:~$ ping 10.0.1.1
PING 10.0.1.1 (10.0.1.1) 56(84) bytes of data.
^C
--- 10.0.1.1 ping statistics ---
2 packets transmitted, 0 received, 100% packet loss, time 1007ms
Page cannot be displayed when attempting to hit the CE on port 8001 or securely at 8003 although the CE shows it's listening
CE#sh gui-server
GUI Server is enabled
Listen on port 8001
Secured GUI Server is enabled
Secured GUI Listen on port 8003
Let me know if there's some other pertinent info, but what am I missing?
0 Replies 0
