Copy running-config startup-config fails
nissanstorage
whenever we try to save the running config to the startup configuration it is failing both from GUI and CLI.
This is the error we are getting..
XYZ# copy running-config startup-config
2013 Nov 21 13:08:46 XYZ %ZONE-2-ZS_INIT_FAILED: Failed to save persistent configuration
2013 Nov 21 13:08:46 XYZ %ZONE-2-ZS_INIT_FAILED: pss_create failure, code = 0x80480011, URL = sync:/mnt/pss/zone_zs_active_zset_cfg
[########################################] 100%
2013 Nov 21 13:08:47 XYZ %SYSMGR-2-CFGWRITE_ABORTED: Configuration copy aborted.
Configuration update aborted: request was aborted
Any suggestions ?
jihicks
Hi Hitesh,
The first thing to check is to determine if compact flash is mounted in ready only mode.
Please see the release note of  CSCeg75552 - EXT3-fs filesystem problem due to transient CompactFlash failure.
Best regards,
Jim
