questions about port-channel
ivy_yangxiaohua
hi, all
i am a newbie of MDS.
now I have questions about port-channel.
currently we configure port-channel on the MDS(MDS9513), which contains 4 members....and We also have 3 other  port-channel
lasfswcor02# sh interface  port-channel 53
port-channel 53 is up
    Port description is "uslas-c6296fi-01-b"
    Hardware is Fibre Channel
    Port WWN is 24:35:00:05:73:e2:5e:40
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port mode is F
    Port vsan is 520
    Speed is 32 Gbps
    5 minutes input rate 492274736 bits/sec, 61534342 bytes/sec, 38284 frames/sec
    5 minutes output rate 3958335744 bits/sec, 494791968 bytes/sec, 261789 frames/sec
      1672665727513 frames input, 2913377399510808 bytes
        0 discards, 0 errors
        0 CRC,  0 unknown class
        0 too long, 0 too short
      5648987822520 frames output, 10407306504402572 bytes
        540 discards, 0 errors
      40 input OLS, 26 LRR, 23 NOS, 0 loop inits
      34 output OLS, 3 LRR, 22 NOS, 9 loop inits
    Member[1] : fc1/1
    Member[2] : fc1/7
    Member[3] : fc2/4
    Member[4] : fc4/28
    Interface last changed at Mon Nov 18 18:23:01 2013
my questions are as below:
1) how do you know which server is using which port-channel ?
2) how do you know how much traffic / or utilization each port is using?
3) how do you see if the port-group is saturated?
Really appreciate your help
thanks in advance!!!!!
Hi Ivy,
Answers inline:
I assume you meant which inteface in the port channel?
They are load balanced, so each server might at any time be using any of the interfaces.
That is one of the benefits of using a port-channel.  If these were individual interfaces not
in a port channel, the servers would be distributed round robin.  The server would be tied to that
interface, ( which you could see in the show flogi database on the MDS ) and could only use
the bandwidth of that one interface.  Also, if that interface goes down, then the server would have
to log back into the fabric over another interface to the MDS.
Use Fabric Manager, Device Manager, Cisco Prime Data Center Network Manager or show interface CLI command.
Use Fabric Manager, Device Manager, or Cisco Prime Data Center Network Manager.
Best regards,
Jim
ivy_yangxiaohua
nobody can help me?
Hi Ivy,
Answers inline:
Best regards,
Jim
Thank you Jim
