dcx rcvd multiple msaps on UCS system Chassis version 4.1(3)N2(1.3c)
dguse
We are getting these errors on 1 blade in our UCS system. We are running b200 blades with 6100 fabric extenders. The blades have the emulex cards. When the errors were coming in the network LED on the front of the blade was out, but the VM'd hosts were all still functioning over the redundant vnic and vhba. Has anyone seen this before.
Subject: System Notification from ucs1com4-A - syslog: - 2011-02-24 16:45:50 GMT-00:00
Severity Level:5
Series:UCS 6100 Series Fabric Interconnect
Switch Priority:7
Device Id:N10-S6100@C@SSI14061021
Server Id:N10-S6100@C@SSI14061021
Time of Event:2011-02-24 16:45:50 GMT-00:00
Message Name:
Message Type:syslog
System Name:ucs1com4-A
Event Description:SYSLOG_ALERT 2011 Feb 24 11:45:50 ucs1com4-A %ETHPORT-2-IF_DOWN_ERROR_DISABLED: Interface Ethernet1/1/1 is down (Error disabled. Reason:DCX rcvd Multiple MSAPs)
syslog_facility:ETHPORT
start chassis information:
Affected Chassis:N10-S6100
Affected Chassis Serial Number:SSI14061021
Affected Chassis Hardware Version:0.0
Affected Chassis Software Version:4.1(3)N2(1.3c)
Affected Chassis Part No:68-3448-03
end chassis information:
Severity Level:5
clyded
We also have inttermittent issues with this as well and several other weird issues that pop up once in a while.  Several code upgrades have just brought different problems.
IF_DOWN_ERROR_DISABLED: Interface Ethernet2/1/6 is down (Error disabled. Reason:DCX rcvd Multiple MSAPs)
