External Mini SAS port/card on a UCS
iantra123
Level 3
Level 3
I'm using a HP Tape Storage ( Ultrium 3280). This tape storage has a SAS cable and I want to connect it on my UCS 220 M3..
Question : What it the Mini-SAS (SFF-8088) card that is compatible with a UCS 220 M3. i.e have an external SAS port.
Antra
sriniach
I had Similar Case, and  found the  Few options.
  1. Options A,  Cisco one is partial support,  however needs to evaluated in this Case.
Cisco Adapter  Supports only  SFF8644   Mini SAS,  Not  SFF-8088 Port.
However there is a cable where you can convert  SFF-8644 to  SFF-8088,   Again this has to be evaluated or Tested in LAB.
   Cisco Product ID
    Cisco 12G 9300-8e 12G SAS HBA for external JBOD attach
   http://www.avagotech.com/products/server-storage/host-bus-adapters/sas-9300-8e
    2 Mini-SAS HD SFF8644
  1. Option B:  ThirdParty  Adapter are available.  It is Straight forward  support SFF-8088 Port,
This supports  Vmware as well.
           Check out Regarding LSI SAS 9207-8E,
http://www.avagotech.com/products/server-storage/host-bus-adapters/sas-9207-8e#specifications
Shopping Places,
http://www.newegg.com/Product/Product.aspx?Item=N82E16816118181
http://www.serversupply.com/products/part_search/pid_lookup.asp?pid=224968&gclid=Cj0KEQjw98mvBRD-_ciSovKhq7gBEiQAEvsBZ2tfbtPVBfZm2dbArotV1ejVjRrJ9i6_P7EDoRGhDBMaAphG8P8HAQ
Cables SFF-8088 to SFF-8088
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1%208000&IsNodeId=1&Description=SFF-8088%20Cables&bop=And&page=1
Hope this helps
