fc alias renaming
stephen2615
Level 3
Level 3
Greetings,
I have a bunch of fc aliases that need to be renamed and they are in zones that are in active zonesets. Can I do this dynamically? If not, what proceedure should I follow?
I created fc aliases for each wwn on a dual port HBA and instead of using port 1 and port 2, I used port 0 and port 1. So I need to rename them to follow a standard.
I am not game to try it on a live system and I don't have any test systems available right now.
Any guidance would be most valuable.
Stephen
fmeetz
Level 4
Level 4
