FC ports show "notConnected" after FC cable connectivity on Nexus 5548
ashb
We have connected new EMC storage array to new FC ports on the Cisco Nexus 5K switches on new.
We have installed SFPs, connected cables and configured/turned on the ports. However, still the port shows status "notConnected". I am not sure what is wrong with the configuration.
Below is the output of the port/interface:
Interface fc2/13: mode[UNINIT] [108c000] Mode: UNINIT State: DOWN Vsan: 4096
VF State: INVALID, admin_tagging_mode 0, vf_tagging_capable 0, log_if_index 0x0
Port wwn: 00:00:00:00:00:00:00:00
B2B credit: 1 Buf size: 0 Multiplier: 0
Perf buffers: 0 bb-scn not-supported cfg_vsan[0]
port_vsan[4096]
phy_port(TRUE) flogi - recv informed(FALSE) acc sent(FALSE)
flogi_allowed(FALSE) Invalid flogis 0
non_volatile - pbuf_reqd[0] reinit_sent[0] suspend_sent [0] prev_vsan[0]
Num of flogis: 0
Num of NPIV logins 0 Num of ELS FLOGI logins 0
FCIDs allocated: 0
Reinit reqd: FALSE
Stats:
mar6 timestamp: Thu Jan 1 00:00:00 1970
Vsan list:
No vsan present in port_vsan_bitset
No evfp vsan present
Below is the output of the port that is connected:
Interface fc2/12: mode[F] [108b000] Mode: F State: UP Vsan: 100
VF State: INVALID, admin_tagging_mode 2, vf_tagging_capable 0, log_if_index 0x0
Port wwn: 20:4c:8c:60:4f:26:40:c0
B2B credit: 16 Buf size: 2112 Multiplier: 0
Perf buffers: 0 bb-scn not-supported cfg_vsan[100]
port_vsan[100]
phy_port(TRUE) flogi - recv informed(TRUE) acc sent(TRUE)
flogi_allowed(TRUE) Invalid flogis 0
non_volatile - pbuf_reqd[0] reinit_sent[0] suspend_sent [0] prev_vsan[100]
Num of flogis: 1
Num of NPIV logins 0 Num of ELS FLOGI logins 1
FCIDs allocated: 1
Reinit reqd: FALSE
Permanent Port Name: [50:01:24:81:00:65:ab:da]
NPIV was accepted: FALSE
Stats:
mar6 timestamp: Wed Apr 19 15:34:50 2017
MSG_FLOGI: 1
MSG_FC2_ACCEPT_OUT: 1
MSG_LCP_INIT_DONE: 1
Vsan list:
100
Vsan no: 100 Max flogi key: 0x1(1) num_fl[0x1]
logged[0x1]
flogi bitset: 0
Kindly guide me in this.
ashb
Hello, can anyone please help me in this? Still not able to get the answer.
Your port is in VSAN 4096 ! The port which is ok is in VSAN 100 !
Please move your port to another VSAN ! 4096 is odd anyway !
