FCIP Peer in the same VLAN
john.mcmanus
Community Member
I will have 2 data centre connected with a 1gb possibly 2 x 1gb ethernet link.
There will be some 802.q trunking between location and some traffic will be routed.
I have the option of having my FCIP peer in the same vlan and carried in the trunk. Or have them in different VLAN and routed between location.
Initiallay I though routed would be good because I can use QoS to prioritise FCIP traffice.
But could I still achieve this using single vlan. and is it allowed.
both site are connect using 6509 with sup720s
John
oerkan
Level 2
Level 2
Hi John,
For the FCIP link it is just an IP connectivity. So, you can do in both ways as you describe. You can route it or use a vlan. Just make sure that you have no too hign RTT. And also there RTT timout setting on FCIP you can play with that according to your RRT in your network.
Hakan.
How could I guarantee bandwidth for FCIP on the 802.1q if I use the same vlan?
regards
John
