FCOE Module part number for VNX 5400
Kshitij Purwar
Hi All,
i want to connect my cisco 6248 FI to VNX 5400 over FCOE,and i need your help to identify FCOE Module part number for VNX and what cables do i require for connectivity.
kshitij
dynamoxxx
Level 5
Level 5
twinax or optical ?  I can tell you that EMC support active twinax only.  As far as the part is concerned you will need to get in touch with your local EMC team/partner.
@dynamoxxx
thanks for quick reply.
I discussed it with EMC they said they dont provide cables,they can provide me only module and i am not sure which module should i order 10G Ethernet or FC.
when i search on google i found out emc provide only one FCOE module -
Two
-Port 10 GbE FCoE Module
FCoE module with two 10 Gb/s Ethernet ports and choice of SFP+optical connection or active twinax copper connection to converged
enhanced E
thernet switch
VNX supports different SLICs (modules),  you can choose from FC, FCoE and iSCSI. You need to decide what you need for your environment.
@dynamoxxx
