FCoE Problem on Nexus 5k
I've configured this topology for FCoE  on 5k
include IBM BaldeCenter with HS23 LOM Emulex  , 2 Nexus4001i , Nexus 5k and MDS 9148 and IBM storwise .
I've configured Fip-snooping on the 4001 and Fcoe on the 5k
please see output config
4001i______
username USERID role network-admin
ip domain-lookup
ip host BC1-N4K-B7 192.168.70.133
switchname BC1-N4K-B7
policy-map type queuing policy-fcoe-bandwidth
  class type queuing 1p7q4t-out-q-default
    bandwidth percent 50
  class type queuing 1p7q4t-out-pq1
    bandwidth percent 7
  class type queuing 1p7q4t-out-q2
    bandwidth percent 7
  class type queuing 1p7q4t-out-q3
    bandwidth percent 7
  class type queuing 1p7q4t-out-q4
    bandwidth percent 7
  class type queuing 1p7q4t-out-q5
    bandwidth percent 7
  class type queuing 1p7q4t-out-q6
    bandwidth percent 7
  class type queuing 1p7q4t-out-q7
    bandwidth percent 7
class-map type network-qos Jumbo1
  match cos 4
class-map type network-qos class-fcoe
  match cos 3
class-map type network-qos class-non-fcoe
  match cos 0-2,4-7
policy-map type network-qos Jumbo
  class type network-qos Jumbo1
    mtu 9216
policy-map type network-qos policy-fcoe
  class type network-qos class-fcoe
    pause no-drop
    mtu 2500
  class type network-qos class-non-fcoe
system qos
  service-policy type network-qos policy-fcoe
  service-policy type queuing output policy-fcoe-bandwidth
snmp-server user admin network-admin auth md5 0xe2bdf918466aea3f614a95deb96670d6 priv 0xe2bdf918466aea3f614a95deb96670d6 localizedkey
snmp-server user USERID network-admin auth md5 0xb84c99a9aa12cdebac674985ecd3eeda priv 0xb84c99a9aa12cdebac674985ecd3eeda localizedkey
vrf context management
  ip route 0.0.0.0/0 10.10.10.2
  ip route 0.0.0.0/0 172.20.16.254
  ip route 0.0.0.0/0 192.168.70.126
vlan 1
vlan 10,30
  fip-snooping enable
ele-fwd pause rate threshold is 1000 pps
interface port-channel2
  switchport mode trunk
  fip-snooping port-mode fcf
  speed 10000
interface Ethernet1/1
  description Blade 1
  switchport trunk allowed vlan 1,10,30
  spanning-tree port type edge trunk
  speed auto
interface Ethernet1/2
  description balde 2
  speed auto
interface Ethernet1/3
  description Blade 3
    bandwidth percent 7
  match cos 4
  match cos 3
  match cos 0-2,4-7
    mtu 9216
    pause no-drop
    mtu 2500
system qos
vlan 1
vlan 10,30
  fip-snooping enable
  speed 10000
interface port-channel20
  speed 10000
  description Blade 1
  speed auto
  description balde 2
  speed auto
  description Blade 3
  speed auto
i
interface Ethernet1/15
  speed 10000
  channel-group 2 mode active
interface Ethernet1/16
  speed 10000
BC1-N4K-B7# sh fip-snooping enode
  Legend:
Interface   VLAN     NODE NAME        FIP MAC         FCOE MAC         FC_MAP
Eth1/3      10   20:00:40:f2:e 40:f2:e9:87:9f:d9  0e:fc:00:ca:00:00  0x0efc00
                 9:87:9f:d9
Eth1/2      10   20:00:40:f2:e 40:f2:e9:87:9e:89  0e:fc:00:ca:00:40  0x0efc00
                 9:87:9e:89
Eth1/1      10   20:00:40:f2:e 40:f2:e9:87:aa:81  0e:fc:00:ca:00:20  0x0efc00
                 9:87:aa:81
BC1-N4K-B7# sh fip-snooping sessions
  Legend:
  FCF MAC                ENode MAC       VLAN      FCoE MAC         N_PORT_ID
00:2a:6a:e6:7a:b8    40:f2:e9:87:9f:d9  10      0e:fc:00:ca:00:00  ca:00:00
00:2a:6a:e6:7a:b8    40:f2:e9:87:9e:89  10      0e:fc:00:ca:00:40  ca:00:40
00:2a:6a:e6:7a:b8    40:f2:e9:87:aa:81  10      0e:fc:00:ca:00:20  ca:00:20
BC1-N4K-B7# sh fip-snooping fcf
  Legend:
Interface VLAN Active FPMA/ FCMAP      FCF-MAC   Pri   Switch WWN  Fabric Name
               Enodes SPMA
por2      10   3      FPMA 0x0efc00 00:2a:6a:e6  128  20:01:00:2a: 20:01:00:2a:
                                    :7a:b8            6a:e6:7a:81  6a:bd:d0:89
Configuration 5K
no password strength-check
fips mode enable
ip domain-lookup
system qos
  service-policy type queuing input fcoe-default-in-policy
  service-policy type queuing output fcoe-default-out-policy
  service-policy type qos input fcoe-default-in-policy
  service-policy type network-qos fcoe-default-nq-policy
slot 1
  port 43-48 type fc
snmp-server user admin network-admin auth md5 0xa2cb00ecf5b7620a73e5eaf25979420c
 priv 0xa2cb00ecf5b7620a73e5eaf25979420c localizedkey
rmon event 1 log trap public description FATAL(1) owner PMON@FATAL
rmon event 2 log trap public description CRITICAL(2) owner PMON@CRITICAL
rmon event 3 log trap public description ERROR(3) owner PMON@ERROR
rmon event 4 log trap public description WARNING(4) owner PMON@WARNING
rmon event 5 log trap public description INFORMATION(5) owner PMON@INFO
fcdomain fcid database
  vsan 1 wwn 10:00:40:f2:e9:87:9f:d9 fcid 0x00ca0000 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:aa:81 fcid 0x00ca0020 dynamic
  vsan 1 wwn 10:00:40:f2:e9:87:9e:89 fcid 0x00ca0040 dynamic
interface san-port-channel 1
  speed 10000
interface vfc101
  bind mac-address 40F2.E987.AA81
  no shutdown
interface vfc102
  bind mac-address 40F2.E987.9E89
  no shutdown
interface vfc103
  bind mac-address 40F2.E987.9FD9
  no shutdown
interface fc1/43
interface fc1/44
interface fc1/45
interface fc1/46
interface fc1/47
  channel-group 1 force
  no shutdown
interface fc1/48
  no shutdown
interface Ethernet1/4
interface Ethernet1/5
interface Ethernet1/6
interface Ethernet1/7
interface Ethernet1/8
interface Ethernet1/9
interface Ethernet1/32
interface Ethernet1/33
interface Ethernet1/34
interface Ethernet1/35
interface Ethernet1/42
interface mgmt0
  vrf member management
  ip address 172.20.16.181/24
line console
line vty
boot kickstart bootflash:/n5000-uk9-kickstart.7.0.2.N1.1.bin
boot system bootflash:/n5000-uk9.7.0.2.N1.1.bin
interface fc1/43
interface fc1/44
interface fc1/45
interface fc1/46
interface fc1/47
interface fc1/48
zoneset activate name ZONESET_V1 vsan 1
N5K96UP-1# show flogi database
INTERFACE        VSAN    FCID           PORT NAME               NODE NAME
vfc101           1     0xca0020  10:00:40:f2:e9:87:aa:81 20:00:40:f2:e9:87:aa:81
vfc102           1     0xca0040  10:00:40:f2:e9:87:9e:89 20:00:40:f2:e9:87:9e:89
vfc103           1     0xca0000  10:00:40:f2:e9:87:9f:d9 20:00:40:f2:e9:87:9f:d9
Total number of flogi = 3.
N5K96UP-1# sh fcoe database
INTERFACE       FCID            PORT NAME               MAC ADDRESS
vfc101          0xca0020        10:00:40:f2:e9:87:aa:81 40:f2:e9:87:aa:81
vfc102          0xca0040        10:00:40:f2:e9:87:9e:89 40:f2:e9:87:9e:89
vfc103          0xca0000        10:00:40:f2:e9:87:9f:d9 40:f2:e9:87:9f:d9
N5K96UP-1# sh int vfc 102
vfc102 is trunking
    Bound MAC is 40:f2:e9:87:9e:89
    Hardware is Ethernet
    Port WWN is 20:65:00:2a:6a:e6:7a:bf
    Admin port mode is F, trunk mode is on
    snmp link state traps are enabled
    Port mode is TF
    Port vsan is 1
    Trunk vsans (admin allowed and active) (1)
    Trunk vsans (up)                       (1)
    Trunk vsans (isolated)                 ()
    Trunk vsans (initializing)             ()
    1 minute input rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
    1 minute output rate 0 bits/sec, 0 bytes/sec, 0 frames/sec
      0 frames input, 0 bytes
        0 discards, 0 errors
      0 frames output, 0 bytes
    last clearing of "show interface" counters never
    Interface last changed at Mon Aug 31 14:23:21 2015
N5K96UP-1# sh fcns database
VSAN 1:
FCID        TYPE  PWWN                    (VENDOR)        FC4-TYPE:FEATURE
0x8f0000    N     50:05:07:68:03:11:3c:11 (IBM)           scsi-fcp:target
0x8f0100    N     50:05:07:68:03:0d:3c:11 (IBM)           scsi-fcp:target
0x8f0200    N     50:05:07:68:03:05:3c:10 (IBM)           scsi-fcp:target
0x8f0300    N     50:05:07:68:03:09:3c:10 (IBM)           scsi-fcp:target
0x8f0400    N     50:05:07:68:03:05:3e:b3 (IBM)           scsi-fcp:target
0x8f0500    N     50:05:07:68:03:09:3e:b3 (IBM)           scsi-fcp:target
0x8f0700    N     50:05:07:68:03:11:3e:b3 (IBM)           scsi-fcp:target
0x8f0900    N     20:05:00:c0:dd:28:8b:56 (Qlogic)
0x8f0a00    N     20:04:00:c0:dd:28:8b:56 (Qlogic)
0x8f0b00    N     20:03:00:c0:dd:28:8b:56 (Qlogic)
0x8f0c00    N     50:01:43:80:28:ca:b5:e2 (HP)            scsi-fcp:init
0xca0000    N     10:00:40:f2:e9:87:9f:d9                 scsi-fcp:init
0xca0020    N     10:00:40:f2:e9:87:aa:81                 scsi-fcp:init
0xca0040    N     10:00:40:f2:e9:87:9e:89                 scsi-fcp:init
Total number of entries = 14
flogi database is ok but i don't see  any LUN on the Vmware
please see screenshot from vmware in  the attachment.
i want to know why i dont see LUN on the vmware or why counter is zero in  interface VFC 102 ?
thanks
Hi Mohammadreza,
Yes, I see you used "Quick Config"  with Device Manager to zone, zoned by interface and switch WWN.
That is fine for a standalone switch and the devices connected to it.
You will need to zone these devices to whichever storage they need to see:
Zone using the "PORT NAMEs".
MDS Quick Config - Zoning
Best regards,
Jim
8 Replies 8
jihicks
Hi Mohammadreza,
How about your zoning, do you have the host on the blade center zoned with storage?
Counters being zero is a little odd
Best regards,
Jim.
Dear Jihicks
Do I really need to do configuration zone on the MDS between Host and Storage?
please see configuration of MDS
  rule 5 permit show feature environment
  rule 4 permit show feature hardware
  rule 3 permit show feature module
  rule 2 permit show feature snmp
  rule 1 permit show feature system
username admin password 5 $1$vI5/VKLH$h6Nfa0sTjmk0XEs6dxRnr0  role network-admin
ip domain-lookup
ip host 172.20.16.246 172.20.16.246
aaa group server radius radius
snmp-server user admin network-admin auth md5 0x073f899d951d1aee6f460addededf71a priv 0x073f899d951d1aee6f460addededf71a localizedkey
snmp-server host 172.20.12.40 traps version 2c public  udp-port 1163
snmp-server host 172.20.12.40 traps version 2c public  udp-port 1164
snmp-server host 172.20.12.40 traps version 2c public  udp-port 1167
  vsan 1 wwn 50:05:07:68:03:11:3c:11 fcid 0x8f0000 dynamic
  vsan 1 wwn 50:05:07:68:03:0d:3c:11 fcid 0x8f0100 dynamic
  vsan 1 wwn 50:05:07:68:03:05:3c:10 fcid 0x8f0200 dynamic
  vsan 1 wwn 50:05:07:68:03:09:3c:10 fcid 0x8f0300 dynamic
  vsan 1 wwn 50:05:07:68:03:05:3e:b3 fcid 0x8f0400 dynamic
  vsan 1 wwn 50:05:07:68:03:09:3e:b3 fcid 0x8f0500 dynamic
  vsan 1 wwn 50:05:07:68:03:0d:3e:b3 fcid 0x8f0600 dynamic
  vsan 1 wwn 50:05:07:68:03:11:3e:b3 fcid 0x8f0700 dynamic
  vsan 1 wwn 21:00:00:24:ff:36:7e:85 fcid 0x8f0800 dynamic
  vsan 1 wwn 20:05:00:c0:dd:28:8b:56 fcid 0x8f0900 dynamic
  vsan 1 wwn 20:04:00:c0:dd:28:8b:56 fcid 0x8f0a00 dynamic
  vsan 1 wwn 20:03:00:c0:dd:28:8b:56 fcid 0x8f0b00 dynamic
interface port-channel 1
  channel mode active
  switchport rate-mode dedicated
interface port-channel 2
ip default-gateway 172.20.16.254
--More--
line console
--More--
boot kickstart bootflash:/m9100-s3ek9-kickstart-mz.5.0.1a.bin
boot system bootflash:/m9100-s3ek9-mz.5.0.1a.bin
interface fc1/1
interface fc1/2
interface fc1/3
interface fc1/4
interface fc1/5
interface fc1/6
interface fc1/7
interface fc1/8
interface fc1/9
interface fc1/10
interface fc1/11
interface fc1/12
interface fc1/13
interface fc1/14
interface fc1/15
interface fc1/16
interface fc1/17
interface fc1/18
interface fc1/19
interface fc1/20
interface fc1/21
interface fc1/22
interface fc1/23
interface fc1/24
interface fc1/25
interface fc1/26
interface fc1/27
interface fc1/28
interface fc1/29
interface fc1/30
interface fc1/31
interface fc1/32
interface fc1/33
interface fc1/34
interface fc1/35
interface fc1/36
interface fc1/37
--More--
interface fc1/38
interface fc1/39
interface fc1/40
interface fc1/41
interface fc1/42
interface fc1/43
interface fc1/44
interface fc1/45
interface fc1/46
interface fc1/47
interface fc1/48
interface fc1/1
interface fc1/2
!Full Zone Database Section for vsan 1
zone name Z_FC1_14_FC1_3_V1 vsan 1
    member interface fc1/14 swwn 20:00:00:2a:6a:bd:d0:88
    member interface fc1/3 swwn 20:00:00:2a:6a:bd:d0:88
zone name Z_FC1_14_FC1_4_V1 vsan 1
    member interface fc1/4 swwn 20:00:00:2a:6a:bd:d0:88
zone name Z_FC1_14_FC1_5_V1 vsan 1
    member interface fc1/5 swwn 20:00:00:2a:6a:bd:d0:88
zone name Z_FC1_14_FC1_6_V1 vsan 1
    member interface fc1/6 swwn 20:00:00:2a:6a:bd:d0:88
zone name Z_FC1_14_FC1_7_V1 vsan 1
    member interface fc1/7 swwn 20:00:00:2a:6a:bd:d0:88
zone name Z_FC1_14_FC1_8_V1 vsan 1
    member interface fc1/8 swwn 20:00:00:2a:6a:bd:d0:88
zone name Z_FC1_14_FC1_9_V1 vsan 1
    member interface fc1/9 swwn 20:00:00:2a:6a:bd:d0:88
--More--
zone name Z_FC1_14_FC1_10_V1 vsan 1
    member interface fc1/10 swwn 20:00:00:2a:6a:bd:d0:88
zone name Z_FC1_47_FC1_3_V1 vsan 1
    member interface fc1/47 swwn 20:00:00:2a:6a:bd:d0:88
zone name Z_FC1_47_FC1_4_V1 vsan 1
zone name Z_FC1_47_FC1_5_V1 vsan 1
zone name Z_FC1_47_FC1_6_V1 vsan 1
zone name Z_FC1_47_FC1_7_V1 vsan 1
zone name Z_FC1_47_FC1_8_V1 vsan 1
zone name Z_FC1_47_FC1_9_V1 vsan 1
zone name Z_FC1_47_FC1_10_V1 vsan 1
zone name Z_FC1_48_FC1_3_V1 vsan 1
    member interface fc1/48 swwn 20:00:00:2a:6a:bd:d0:88
--More--
zone name Z_FC1_48_FC1_4_V1 vsan 1
zone name Z_FC1_48_FC1_5_V1 vsan 1
zone name Z_FC1_48_FC1_6_V1 vsan 1
zone name Z_FC1_48_FC1_7_V1 vsan 1
zone name Z_FC1_48_FC1_8_V1 vsan 1
zone name Z_FC1_48_FC1_9_V1 vsan 1
zone name Z_FC1_48_FC1_10_V1 vsan 1
zoneset name ZONESET_V1 vsan 1
    member Z_FC1_14_FC1_3_V1
    member Z_FC1_14_FC1_4_V1
    member Z_FC1_14_FC1_5_V1
    member Z_FC1_14_FC1_6_V1
    member Z_FC1_14_FC1_7_V1
    member Z_FC1_14_FC1_8_V1
    member Z_FC1_14_FC1_9_V1
    member Z_FC1_14_FC1_10_V1
    member Z_FC1_47_FC1_3_V1
    member Z_FC1_47_FC1_4_V1
    member Z_FC1_47_FC1_5_V1
    member Z_FC1_47_FC1_6_V1
    member Z_FC1_47_FC1_7_V1
    member Z_FC1_47_FC1_8_V1
    member Z_FC1_47_FC1_9_V1
    member Z_FC1_47_FC1_10_V1
    member Z_FC1_48_FC1_3_V1
    member Z_FC1_48_FC1_4_V1
    member Z_FC1_48_FC1_5_V1
    member Z_FC1_48_FC1_6_V1
    member Z_FC1_48_FC1_7_V1
    member Z_FC1_48_FC1_8_V1
    member Z_FC1_48_FC1_9_V1
    member Z_FC1_48_FC1_10_V1
interface fc1/1
  port-license acquire
  no shutdown
interface fc1/2
  no shutdown
interface fc1/3
  no shutdown
interface fc1/4
  no shutdown
interface fc1/5
  no shutdown
interface fc1/6
  no shutdown
--More--
interface fc1/7
  no shutdown
interface fc1/8
  no shutdown
interface fc1/9
  no shutdown
interface fc1/10
  no shutdown
interface fc1/11
  no shutdown
interface fc1/12
  no shutdown
interface fc1/13
  no shutdown
interface fc1/14
  no shutdown
interface fc1/15
  no shutdown
interface fc1/16
  no shutdown
interface fc1/17
--More--
  no shutdown
interface fc1/18
  no shutdown
interface fc1/19
interface fc1/20
interface fc1/21
interface fc1/22
interface fc1/23
interface fc1/24
interface fc1/25
interface fc1/26
interface fc1/27
interface fc1/28
interface fc1/29
interface fc1/30
--More--
interface fc1/31
interface fc1/32
interface fc1/33
interface fc1/34
interface fc1/35
interface fc1/36
interface fc1/37
interface fc1/38
interface fc1/39
interface fc1/40
interface fc1/41
interface fc1/42
interface fc1/43
  no shutdown
--More--
interface fc1/44
interface fc1/45
interface fc1/46
interface fc1/47  ----> Nexus 5K
  channel-group 2 force
  no shutdown
interface fc1/48  ----> Nexus 5K
  no shutdown
interface mgmt0
  ip address 172.20.16.246 255.255.255.0
switch#
many thanks
Hi Mohammadreza,
Best regards,
Jim
Hi Jihicks
thanks your support . I could use your help for solved this issue .
but i have little problem. the speed between blade and storage is very slow ,less than 1Mbps. Do Low speed is because of the QOS settings or Something else.
many thanks
Hi Mohammadreza
Looks like you have a port-channel between the N5K and the N4K.
Try this command as a test to see if it fixes the throughput problem.
N5K(config)# port-channel load-balance ethernet source-dest-port <-- Default is src/dst mac. This way, only one link will be utilized, which is why we change it to src/dst port.
Best regards,
Jim
hi jim
thanks  for your support.
I did change that you said , i did  port-channel between the N5K and the N4K.
But still have problems. This scenario is not now under operation.sometime traffic between esxi and storage is good but  This relation is suddenly interrupted or slow speed.i think this issue is due to qos or jumbo frame.please tell your comment.
many thanks
Hi Mohammadreza,
Please take a look at Bug ID CSCts95953:
https://tools.cisco.com/bugsearch/bug/CSCts95953
This is a bug where the system QOS is not being applied to the port-channel and the workaround is to apply it directly to the port-channel but this is quite old.
Please look at each of these:
CSCts56466    N4k: Uplink interfaces err-disable with fix of CSCtq71652 ...
CSCtq71652    N4k stops processing FIP when it receives excessive pause frames
CSCtx34517    PFC frames increasing RX PAUSE counter for all Queues
CSCue18865    Auto-recovery on server ports err-disable
CSCty66618    FIP snooping stops working after some time
CSCts95953    System Queuing Policy does not get applied to port-channel
Best regards,
Jim
Hi Jim
thanks you for support .your previous post was very helpful.
I've changed the configuration in the 4k please see the attachment .each Blade has two nexus 4k and two 4K connect one 5k.window server in a blade see LUN of storage and also attach to disk in the windows but i have a problem  in the transferring file to storage please see attachment also i have a problem with Esxi in the others blades .they see LUNs on both path  but i could not add to storage of Esxi .
also i see on interface connect to cna adaptor this error
Rx
    81256318 input packets 81237230 unicast packets 17730 multicast packets
    1352 broadcast packets 77204828 jumbo packets 0 storm suppression packets
    164668129378 bytes
    22 Rx pause
    510 input discard
please help me about this problem
