Flow control
edondurguti
Level 4
Level 4
I have two nexus 5k connected via port channel and two UCS also attached to 5k via port-channel, it's SAN[iscsi]/ LAN shared segment.
Do you guys think I should enable flow control on the trunk clinks between 2 nexus5ks and the UCS Fiber interconnect?
richbarb
If you are using ESX, is a best practical you enable flow control in the N5K.
Richard,
Thanks for your reply, it's best practice to enable flow control between UCS and  nexus 5K or enable flow control between trunk links in nexus 5k?
All servers in UCS are running ESXi 5.1
