How to install Cisco Device Manger on Window 7
Chetan R
Hello
Is Cisco device manager supported on windows 7 ?
If yes how to install Cisco Device Manger on Window 7?
Please advise
Chetan R
calopez2
You can install the latest DCNM 5.x  for support, please see here:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/dcnm/release/notes/dcnm_5_1_relnotes.html#wp179665
Support for Windows 7 and Windows 2008
In Cisco DCNM Release 5.1(3u), the Cisco DCNM server supports Windows 2008 and the Cisco DCNM client support Windows 7.
You can download the DCNM from the Software Download. Device Manager is bundled in DCNM.
For DCNM-SAN installation please see here:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/dcnm/installation/guide/inst_troubleshoot.html
I hope this helps.
Carlos
kenk
Hello Chetan,
Per the Fabric Manager release notes, it appears that official support for Windows 7 is not there yet.
However, you can install Device Manager on Windows 7 Enterprise edition (use at your own risk as it would be unsupported) easily by pointing your browser to the MDS switch's mgmt0 IP address (assuming you have IP connectivity from the browser to the MDS).  You will be presented with an option to download Device Mgr. from the switch itself.
Ken
