hyperflex
naveed.ahmad
Community Member
hi everyone i need to ask do we need to install os on hyperflex and manage netwroks between compute and other other nodes or cisco did it already or we just need to plugin and use it?
Clifford Aldan
HyperFlex is supported on VMware ESXi or Hyper-V, which in turn supply their own virtual switches to manage VM networks. Please review the preinstallation checklist for more information: https://www.cisco.com/c/en/us/td/docs/hyperconverged_systems/HyperFlex_HX_DataPlatformSoftware/HyperFlex_Preinstall_Checklist/b_HX_Data_Platform_Preinstall_Checklist.html
bezeddin
Level 4
Level 4
@naveed.ahmad
Hyperflex OS will be ESXi or Hyper-V and storage controller deployed as virtual
HX installer will push config to the UCSM, ESXi to deploy HXDP on each node and finally create Hyperflex cluster
During installation VM network will be configured as well (you can also manually add vswitch after installation)
jvdmade
With a new HyperFlex cluster, it comes with an OS.
During the installation of a HyperFlex cluster with Fabric Interconnects, the network connection to the FIs are also configured.
Kind Regards,
Joost.
Kind Regards,
Joost.
