iscsi with Etherchannel isn't working
aolabisi
is there any reason why a qlogic iscsi initiator can't establish an iscsi session with an IPS module via a port-channel interface? it successfully establishes a session with a single interface on the same IPS module.
dayo
7 Replies 7
mrfrase
Should work, would like to see Ethernet switch configuration and IPS8 config. What version firmware are you running on the Qlogic iSCSI HBA. We may need a TAC case open to dig into this and run debugs.
tblancha
You will need to define the port-channel groups under the ethernet interfaces and have the IP address on the port-channel logical interface as the target IP address. This will not work on the 14+2 cards. Is your initiator able to ping the target IP address? If not, then it is not an iscsi issue as a IP connectivity issue.
My scsi initiator is able to poing the IP address of the port-channel logical interace. I have an IPS-8 module on an mds9509.
if you have access to Cisco TAC cases, I opened a case - check out my "show tech" on case 600848444.
the SE assigned to the case is in Australia - we have a 24-hour turnaround time for mail exchanges... i send him a mail and expect a response the next day.
dayo
Dayo,
Can you please upload relavent parts of the configuration or paste it, please.
Tarun
here you go:
on the MDS:
interface port-channel 1
switchport trunk mode off
ip address 172.16.1.1 255.255.255.0
interface GigabitEthernet7/1
channel-group 1 force
no shutdown
interface GigabitEthernet7/2
no shutdown
interface GigabitEthernet7/3
ip address 172.16.1.3 255.255.255.0
no shutdown
on the Cat3750:
interface Port-channel1
switchport mode access
no ip address
interface GigabitEthernet1/0/25
no ip address
speed nonegotiate
channel-group 1 mode on
interface GigabitEthernet2/0/25
no ip address
speed nonegotiate
interface GigabitEthernet2/0/24
description iSCSI initiator port
no ip address
speed nonegotiate
I can establish an iSCSI session successfully to 172.16.1.3 (individual port), but I can't establish one to 172.16.1.1
it's the same initiator/target, so the configs are the same on the MDS. I advertise the target on int po1, g7/1, g7/2 and g7/3. all ports are in the same zone and there's no iscsi authentication and no iscsi acl.
dayo
turns out to be a bug in San-OS. Other iscsi initiators are more forgiving - but the Qlogic HBAs I have are not as forgiving... see comments from SE working on the case I opened below:
"I was able to get the sniffer traces for both scenario's (with ether-channel) and without. Looking at the traces, with an ether-channel the Tsih value is always set to 0 from the MDS. When using just an access port, the Tsih value is returned with a non-zero value. My Cisco iscsi driver worked in both scenarios as it is a bit more lenient than your Qlogic. You noted on the case that you are using a QLA4010C iSCSI HBA."
thanks Arnel!
dayo
for the benefit of those following this string - Cisco engineers provided a workaround.
Use port channel number different from 1. I configured port channel 2 and it worked instantly.
dayo
