locate a switch port a wwpn is logged into
Hi, I'm new to cisco so this may be the wrong forum.
However, I'd like to locate which switch an HBA/wwpn is plugged in on a CISCO San.
I can do this easily on a Brocade SAN using 'nodefind' combined with 'fabricshow'
Does anyone know the CLI commands to achieve this?
thanks Rob
Marcin Latosiewicz
Both MDS and N5k provide "show flogi database" and "show fcns database" commands.
This should show you were devices are flogi'd in.
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/4_1/configuration/guides/cli_4_1/clibook/flgi.html
Marcin Latosiewicz
Marcin, thanks I was unaware of the 'show fcns' command - worked perfectly.
thanks Rob
