09-17-2012 04:35 AM
Hello all,
have a quiry hope you can help me.
Im adding a new MDS 9124 NX-OS Release 5.0(1), have already an existing 9509 with the follwing software version:
BIOS: version 1.0.6
kickstart: version 3.2(3)
system: version 3.2(3)
im connecting a new storage through the 9124 and would want the existing servers on the 9509 to be able to communicate with that server, Solution I could find is creating an ISL, been searching for the firmware pre-requsite but couldnt find it. will this work without upgrading the 9509 firmware ?
not much of excperince with MDS switches, am I doing this correctly ?
09-17-2012 04:36 AM
Also another question, will the upgrade be data interaptive ? i.e. will it require reboot or disconnect the ports while uprading.
09-18-2012 06:21 AM
you will need to upgrade 9509 to at least 3.3.1c
If you look at the release notes for 3.3.1c it will tell you if it's a disruptive upgrade (typicall it's not)
