MDS 9509 MIB question
tdeboeser
We've setup a SNMP trap server (net-SNMP). I've believe I have the MDS MIBs, but I get a MIB/OID that even google can't find:
udp:10.31.48.47:32783 [udp:10.31.48.47:32783]: Trap SNMPv2-MIB::sysUpTime.0 = Timeticks: (3193233237) 369 days, 14:05:32.37, SNMPv2-MIB::snmpTrapOID.0 = OID: SNMPv2-SMI::enterprises.9.9.293.1.4.0.3, SNMPv2-SMI::enterprises.9.9.293.1.1.4.1.2.2.3.6.0 = Hex-STRING: 21 00 00 E0 8B 0F 00 E0 , SNMPv2-SMI::enterprises.9.9.293.1.1.4.1.8.2.3.6.0 = INTEGER: 2
I do get correct/readable "link down/up" messages, but I don't know what the above is.
Thanks for any pointers,
Tom De Boeser
tblancha
From the SNMP navigator at http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?objectInput=enterprises.9.9.293.1.4.0.3&translate=Translate&submitValue=SUBMIT&submitClicked=true
this is the fcNameServer Notification which makes sense since the 21 00 00 E0 8B 0F 00 E0 appears to be a fibre channel WWN. So, that is the Cisco-NS-MIB and is a notification. So, assuming I looked up the last digit in the notification in the MIB correctly, the description for 3 is: "This notification is generated by the Name Server when a new entry gets added to the Name Server database."
Thus, It appears the trap is that that PWWN was registered to the nameserver.
tblancha
Ah, nice tool. I wasn't aware of it. And the SNMP message does correlate with syslog messages - we had a host's link go down then up.
Thanks much,
Tom De Boeser
