MDS switch password
srshet
what command is used to change the admin password of the MDS switches
inch
Level 3
Level 3
Hi there,
the same was as you change it for another user! :-)
It also depends if you have aaa configured or not, generally it would be
switch(config)# username admin password my_super_hard_password
Cheers
Andrew
