MDS 9710 SDV feature issue
I have a pair of MDS 9710s and I'm planning to use SDV feature.
The pre-req for the SDV feature is the ENTERPRISE_PKG licence which I do have it installed on the switch :
Feature                      Ins  Lic   Status Expiry Date Comments
                                 Count
FM_SERVER_PKG                 No    -   Unused             -
MAINFRAME_PKG                 No    -   Unused             -
ENTERPRISE_PKG                Yes   -   Unused never       -
But , when I'm trying to enable the feature, I'll get the following error message:
Switch(config)# feature sdv
 Stub Library could not be opened
 *** libsdmcli.so: cannot open shared object file: No such file or directory ***
Switch(config)# show feature | grep disabled
cloud-discovery       1         disabled
dmm                   1         disabled
dpvm                  1         disabled
evmed                 1         disabled
extended_credit       1         disabled
fabric-binding        1         disabled
fcsp                  1         disabled
ficon                 1         disabled
ike                   1         disabled
ioa                   1         disabled
ipsec                 1         disabled
isapi                 1         disabled
iscsi                 1         disabled
isns-server           1         disabled
ivr                   1         disabled
ldap                  1         disabled
onep                  1         disabled
poap                  1         disabled
port-security         1         disabled
port_track            1         disabled
privilege             1         disabled
qos-manager           1         disabled
san_ext_tuner         1         disabled
santap                1         disabled
scpServer             1         disabled
sdv                   1         disabled
sfm                   1         disabled
sftpServer            1         disabled
tacacs                1         disabled
telnetServer          1         disabled
tpc                   1         disabled
Anyone else has the same issue ????
Hi Mohammad,
I absolutely agree, this is what I meant with CSCuv29872.
Best regards,
Jim
5 Replies 5
jihicks
Hi Mohammad,
Seems to be a bug.  I get the same error.
I opened BUG ID CSCuv29872 for this.
Best regards,
Jim
Hi Mohammad,
SDV is a deprecated feature.   The bug I opened will be used to clean up the firmware.  It should not still appear as a feature and should not provide an error message at an attempt to enable it.
Please see:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/sw/6_2/configuration/guides/fabric/nx-os/nx_os_fabric/overview.html#40046
Best regards,
Jim
Thanks for the update Jim.
I believe Cisco still need to address this as a cosmetic bug ;)
Hi Mohammad,
Best regards,
Jim
Thanks again Jim
