MDS scriptig
christoph.reeber
Community Member
Does anyone know about scripting possibilities for the MDS series.
I know the FM Server Database Schema document, but want to script directly the switch.
Many thanks in advance for any idea.
Kind regards,
Chris
9 Replies 9
user_4444
Level 4
Level 4
I have done some basic stuff, see attached. I opened CLI via Putty and just copied and pasted what I wanted to do.
I have removed our IP Addresses from the first section.
Hopefully that helps.
"conf
no ip access-list bogus permit udp 0.0.0.0 any eq port snmp
no ip access-list bogus permit tcp 0.0.0.255 any eq port ssh
no ip access-list bogus permit icmp 0.0.0.255 any icmp-type echo
no ip access-list bogus permit icmp 255.255.255.255 any icmp-type echo
no ip access-list bogus permit tcp 0.0.0.0 any eq port ssh
no ip access-list bogus permit tcp any any eq port www
no ip access-list bogus permit udp any 0.0.0.0 eq port 69
ip access-list bogus permit icmp 0.0.0.0 any
int mgmt0
ip access-group bogus in
end
copy run start"
Tanks for the idea. I will try to use it as foundation for my scriptings.
Kind regards,
Chris
inch
Level 7
Level 7
Hi Christoph,
You can script directly to the switch via ssh keys and/or using snmp 🙂
Cheers
Andrew
Hi Andrew,
thanks for the hint. I just played with plink and looking for more snmp details in combination with the MDS.
Kind regards,
Chris
KevinBeaulieu
Please keep in mind that Cisco doesn't officially support scripting to the switch and there are known problems in using it. Scripts that run fine at one version can also break as I've experience at new SAN-OS versions. Please keep this in mind when you use scripting.
G'day,
Cisco DO support the command line and if scripting means running commands via the command line and/or via snmp of course they support it.
What they wont support is your actual scripts (obviously).
If you have any issues with running the commands either via command line or snmp (ie: the commands dont do what they should log a case with cisco as things should work as documented).
If in doubt, get in contact with your local SE....
Cheers
Andrew
marsnow
Community Member
You can create scripts on the switch using the scheduler command.
You create a schedule job and enter the commands you want to run, then choose how often to run it. You can also output it to a file on bootflash: and ftp off to a server as part of the scheduled job.
This tells you how to use the scheduler.
http://cco/en/US/docs/storage/san_switches/mds9000/sw/rel_3_x/configuration/guides/cli_3_4_x/maint.html
andre
Community Member
...or you give expect a try. I'm using it since my early Cisco days
Andre
We are using MDS Cisco Fabric switch.I would like to know more about scirpting documentation for switch.
everytime we need to add the port descrition manually via DM.Could u please someone suggest how that can be managed by script.We have mulpiple server description need to add in DM.How that can be do it via script:
For Example:
Suppose i would like to add port description to Port fc12/21 on switch following is syntax how that i can run on for mulpiple servers:
config
interface fc12/21
switchport description XYZ (SP1)
no shutdown
end
show interface fc12/21
Please suggest.
