More Zone merge questions.
wghussey1
I am merging pur Dev switch with our Prod switch. Each have very similar zonesets in vsan2. They do have uniques zones but the zoneset name is the same.
I want to make sure that my settings are correct so when I ISL the swithces that the zones from Dev propegate to Prod. I am confuesd if I have to use the zone copy vsan 2 active-zoneset comman or not. I know once the merge is complete i have to save the running config into startup.
I just want to make sure VSAN2 on dev does not overwright VSAN2 in prod. Read all the documents. My configs are below
Production
VSAN: 2 default-zone: deny distribute: active only Interop: default
    mode: basic merge-control: allow
    session: none
    hard-zoning: enabled broadcast: disabled
Default zone:
    qos: none broadcast: disabled ronly: disabled
Full Zoning Database :
    DB size: 70988 bytes
    Zonesets:1  Zones:488 Aliases: 130
Active Zoning Database :
    DB size: 32724 bytes
    Name: Kforce_Zoneset  Zonesets:1  Zones:480
Status: Activation completed at 13:25:18 EST Jul 30 2012
Development (to be merged into production)
Ybor-Top-Switch-RYC1SS01# show zone status vsan 2
    session: none
Default zone:
    DB size: 18940 bytes
    Zonesets:1  Zones:129 Aliases: 44
    DB size: 8596 bytes
    Name: KFORCE_ZONESET  Zonesets:1  Zones:129
Status: Activation completed at 17:58:29 UTC Jul 30 2012
dakester
I did read this. My only concern is the fact that my actirve zoneset have the same name
One is Kforce_Zoneset and the other is KFORCE_ZONESET. Other than that should be easy I was thinking
