N55-8P-SSK9= license for N5K-C5548UP
shahid2
I am looking to install N55-8P-SSK9= license on my N5K-C5548UP switch to enable 8 ports for storage.
Can I add one more license to my same switch to enable 8 more ports for storage that is 16 ports in total?
5 Replies 5
marce1000
   - Checkout this thread : https://community.cisco.com/t5/storage-networking/how-to-install-2-x-l-n55-8p-ssk9-in-n5k-c5596up-fa/td-p/1839192
  M.
Thanks for the reference link. Could you please also check this link and let me know whether its correct or not?
 - @shahid2  Yes , that info is correct
 M.
So does it mean that I can keep on adding 8 ports license each time when i want and the switch wont show the following error?
# install license bootflash:MDS20111124032427514.lic
Installing license failed: A permanent license already exists for the feature
 - @shahid2  The license is honor based , you only need to install it once and you will be able to use the other FC ports also ,
 M.
