Nexus 2K 10Gb connectivity issue with Netapp SAN
abbasali5
I have a customer who have Nexus 2K 10Gb connected to NetAPP SAN, but they are only getting 10Mb.  The statistics also shows a lots of CRC error.  Not sure, if there is any need to turn on some additional features on the port or could be a bug on the Nexus OS.
Any advise will be appreciated.
Nexus 2K port configuration below:
interface Ethernet103/1/25
  description < DR SAN REPLICATION TEMP - NIC N1-e0b >
  switchport
  switchport access vlan 220
  spanning-tree port type edge
  no shutdown
netappcluster::> net port show -port e0b -fields node,port,mtu,duplex-admin,duplex-oper,speed-admin,flowcontrol-admin,ipspace
  (network port show)
node             port mtu  duplex-admin duplex-oper speed-admin flowcontrol-admin ipspace
netappcluster-01 e0b  1500 full         full        10000       none              Default
netappcluster-02 e0b  1500 full         full        10000       none              Default
2 entries were displayed.
Mark Malone
Hi crcs are a layer 1 issue are they been seen on Nexus port can you post the output please of the show interface e103/1/25 ?
How may interfaces are connected to the SAN from the Nexus and whats the uplink speed to the 5ks 20 or 40?
Are there many other devices connected to the 2k and do they receive the speed they should
We need more information:
- what kind of IP storage protocol ? iSCSI or NFS ?
- which OS ? and of ESXi, which virtual switch ? vswitch, VMware DVS, Cisco N1k ?
- detailed configuration of the virtual switch ? load balancing setup ?
and
it is not best practise, to attach a Netapp filer to a N2k, due to oversucription; storage folks would like to have a 10G non oversubsribed connectivity ! connect the Netapp directly to a 10G ports on a N5k,... switch.
Thanks Mark and Walter,
Please see below the output from show interfaces ethernet 103/1/25-28 in question.
Also included the hardware and software version at the end.
MDF-DC1# show int ethernet 103/1/25
Ethernet103/1/25 is up
admin state is up
  Hardware: 1000/10000 Ethernet, address: 5ca4.8a8c.2c1a (bia 5ca4.8a8c.2c1a)
  Description: < DR SAN REPLICATION TEMP - NIC N1-e0b >
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec
  Encapsulation ARPA, medium is broadcast
  Port mode is access
  full-duplex, 10 Gb/s, media type is 10G
  Beacon is turned off
  Auto-Negotiation is turned on
  Input flow-control is off, output flow-control is off
  Auto-mdix is turned off
  Rate mode is dedicated
  Switchport monitor is off
  EtherType is 0x8100
  Last link flapped 1week(s) 0day(s)
  Last clearing of "show interface" counters 6w5d
  2 interface resets
  Load-Interval #1: 30 seconds
    30 seconds input rate 224 bits/sec, 0 packets/sec
    30 seconds output rate 552 bits/sec, 0 packets/sec
    input rate 224 bps, 0 pps; output rate 552 bps, 0 pps
  Load-Interval #2: 5 minute (300 seconds)
    300 seconds input rate 3968 bits/sec, 1 packets/sec
    300 seconds output rate 4520 bits/sec, 1 packets/sec
    input rate 3.97 Kbps, 1 pps; output rate 4.52 Kbps, 1 pps
  RX
    4885014 unicast packets  65990 multicast packets  2685 broadcast packets
    4953689 input packets  1952839989 bytes
    0 jumbo packets  0 storm suppression packets
    0 runts  0 giants  0 CRC/FCS  0 no buffer
    0 input error  0 short frame  0 overrun   0 underrun  0 ignored
    0 watchdog  0 bad etype drop  0 bad proto drop  0 if down drop
    0 input with dribble  0 input discard
    0 Rx pause
  TX
    4956095 unicast packets  992224 multicast packets  196687 broadcast packets
    6215724 output packets  2149545682 bytes
    8524 jumbo packets
    0 output error  0 collision  0 deferred  0 late collision
    0 lost carrier  0 no carrier  0 babble  0 output discard
    0 Tx pause
MDF-DC1# show int ethernet 103/1/26
Ethernet103/1/26 is up
admin state is up
  Hardware: 1000/10000 Ethernet, address: 5ca4.8a8c.2c1b (bia 5ca4.8a8c.2c1b)
  Description: < DR SAN REPLICATION TEMP - NIC N2-e0b >
  Port mode is access
  EtherType is 0x8100
  3 interface resets
    30 seconds input rate 1960 bits/sec, 1 packets/sec
    30 seconds output rate 2448 bits/sec, 2 packets/sec
    input rate 1.96 Kbps, 1 pps; output rate 2.45 Kbps, 2 pps
    300 seconds input rate 29488 bits/sec, 42 packets/sec
    300 seconds output rate 1605320 bits/sec, 136 packets/sec
    input rate 29.49 Kbps, 42 pps; output rate 1.61 Mbps, 136 pps
  RX
    75478175 unicast packets  65991 multicast packets  2757 broadcast packets
    75546923 input packets  7471402824 bytes
    0 Rx pause
  TX
    229664577 unicast packets  992257 multicast packets  196620 broadcast packet
s
    235653630 output packets  336314440639 bytes
    147281 jumbo packets
    0 Tx pause
MDF-DC1# show int ethernet 103/1/27
Ethernet103/1/27 is up
admin state is up
  Hardware: 1000/10000 Ethernet, address: 5ca4.8a8c.2c1c (bia 5ca4.8a8c.2c1c)
  Description: < NetApp Prod SAN FCoE - N1-e0b >
  Port mode is access
  EtherType is 0x8100
  2 interface resets
    30 seconds input rate 1248 bits/sec, 1 packets/sec
    30 seconds output rate 1904 bits/sec, 1 packets/sec
    input rate 1.25 Kbps, 1 pps; output rate 1.90 Kbps, 1 pps
    300 seconds input rate 1509536 bits/sec, 126 packets/sec
    300 seconds output rate 27192 bits/sec, 38 packets/sec
    input rate 1.51 Mbps, 126 pps; output rate 27.19 Kbps, 38 pps
  RX
    201528825 unicast packets  65993 multicast packets  4023 broadcast packets
    201598841 input packets  292255465031 bytes
    0 Rx pause
  TX
    62933326 unicast packets  1022485 multicast packets  195360 broadcast packet
s
    64239330 output packets  6684406470 bytes
    8984 jumbo packets
    30222 Tx pause
MDF-DC1# show int ethernet 103/1/28
Ethernet103/1/28 is up
admin state is up
  Hardware: 1000/10000 Ethernet, address: 5ca4.8a8c.2c1d (bia 5ca4.8a8c.2c1d)
  Description: < NetApp Prod SAN FCoE - N2-e0b >
  Port mode is access
  EtherType is 0x8100
  2 interface resets
    30 seconds input rate 1208 bits/sec, 1 packets/sec
    30 seconds output rate 1312 bits/sec, 1 packets/sec
    input rate 1.21 Kbps, 1 pps; output rate 1.31 Kbps, 1 pps
    300 seconds input rate 119536 bits/sec, 12 packets/sec
    300 seconds output rate 6768 bits/sec, 5 packets/sec
    input rate 119.54 Kbps, 12 pps; output rate 6.77 Kbps, 5 pps
  RX
    40794461 unicast packets  65994 multicast packets  4030 broadcast packets
    40864485 input packets  50256267733 bytes
    0 Rx pause
  TX
    17091067 unicast packets  1655188 multicast packets  195348 broadcast packet
s
    19009825 output packets  3050691908 bytes
    8962 jumbo packets
    662912 Tx pause
NX-OS Version of Nexus 7004 (parent to Nexus 2Ks):
MDF-DC1# show ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2014, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
Software
  BIOS:      version 2.12.0
  kickstart: version 6.2(8a)
  system:    version 6.2(8a)
  BIOS compile time:       05/29/2013
  kickstart image file is: bootflash:///n7000-s2-kickstart-npe.6.2.8a.bin
  kickstart compile time:  5/15/2014 20:00:00 [06/20/2014 21:56:57]
  system image file is:    bootflash:///n7000-s2-dk9-npe.6.2.8a.bin
  system compile time:     5/15/2014 20:00:00 [06/20/2014 23:25:18]
Hardware
  cisco Nexus7000 C7004 (4 Slot) Chassis ("Supervisor Module-2")
  Intel(R) Xeon(R) CPU         with 12224948 kB of memory.
  Processor Board ID JAF1716ARAC
  Device name: MDF-DC1
  bootflash:    2007040 kB
  slot0:              0 kB (expansion flash)
Kernel uptime is 80 day(s), 22 hour(s), 10 minute(s), 44 second(s)
Last reset
  Reason: Unknown
  System version: 6.2(8a)
  Service:
plugin
  Core Plugin, Ethernet Plugin
MDF-DC1#
