Nexus 5596 to join Brocade fabric
Rigido1971
Hi all, I tried to search but didn't find a "real" answer, it is not clear if it is possible or not...
Problem: I always worked with homogeneous Brocade fabrics. Some days ago my company asked me if it is possible to add a Nexus 5596UB to an existing (6 switches) production Brocade fabric. I underlined production as we should not interrupt SAN traffic on joining the fabric nor we should reboot and/or reconfigure existing switches.
I found a lot of info about "interoperability mode" on MDS switches but nothing on Nexus.
Can someone help me? Thanks.
According to the datasheet
http://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/data_sheet_c78-618603.html
Native interop 1,2,3 and 4 is supported !
Therefore you are ok, and have a TAC supported configuration.
Fibre Channel and FCoE Features (Requires Storage Services License)
  T11 standards-compliant FCoE (FC-BB-5)
  T11 FCoE Initialization Protocol (FIP) (FC-BB-5)
  Any 10 Gigabit Ethernet port configurable as FCoE
  SAN administration separate from LAN administration
  FCP
  Fibre Channel forwarding (FCF)
  Fibre Channel standard port types: E, F, and NP
  Fibre Channel enhanced port types: VE, TE, and VF
  F-port trunking
  F-port channeling
  Direct attachment of FCoE and Fibre Channel targets
  Up to 240 buffer credits per native Fibre Channel port
  Up to 32 VSANs per switch
  Fibre Channel (SAN) PortChannel
  Native Interop Mode 1
  Native Interop Mode 2
  Native Interop Mode 3
  Native Interop Mode 4
  VSAN trunking
  Fabric Device Management Interface (FDMI)
  Fibre Channel ID (FCID) persistence
  Distributed device alias services
  In-order delivery
  Port tracking
  Cisco N-Port Virtualization (NPV) technology
  N-port identifier virtualization (NPIV)
  Fabric services: Name server, registered state change notification (RSCN), login services, and name-server zoning
  Per-VSAN fabric services
  Cisco Fabric Services
  Diffie-Hellman Challenge Handshake Authentication Protocol (DH-CHAP) and Fibre Channel Security Protocol (FC-SP)
  Host-to-switch and switch-to-switch FC-SP authentication
  Fabric Shortest Path First (FSPF)
  Fabric binding for Fibre Channel
  Standard zoning
  Port security
  Domain and port
  Enhanced zoning
  SAN PortChannels
  Cisco Fabric Analyzer
  Fibre Channel traceroute
  Fibre Channel ping
  Fibre Channel debugging
  Cisco Fabric Manager support
  Storage Management Initiative Specification (SMI-S)
  Boot from SAN over VPC/EVPC
6 Replies 6
Walter Dey
See the Cisco Nexus 5000 Series Switch CLI Software Configuration Guide
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli/CLIConfigurationGuide.pdf
p 601ff
About Interop Mode
Cisco NX-OS software supports the following four interop modes:
• Mode 1— Standards-based interop mode that requires all other vendors in the fabric to be in interop mode.
• Mode 2—Brocade native mode (Core PID 0).
• Mode 3—Brocade native mode (Core PID 1).
• Mode 4—McData native mode.
For information about configuring interop modes 2, 3, and 4, see the Cisco MDS 9000 Family
Switch-to-Switch Interoperability Configuration Guide, available at the following location:
http://www.cisco.com/en/US/docs/storage/san_switches/mds9000/interoperability/guide/intopgd.html
Configuring Interop Mode 1
The interop mode1 in Cisco Nexus 5000 Series switches can be enabled disruptively or nondisruptively.
So in summary: Nexus 5000 only supports standard Interop Mode (Mode 1); which most likely doesn't help you at all.
dynamoxxx
Level 5
Level 5
i would explore of putting N5k into NPV mode
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/sw/configuration/guide/cli_rel_4_0_1a/CLIConfigurationGuide/npv.html
@dynamoxxx
Agreed ! this is essentially the setup of UCS fabric interconnect (NPV mode) attached to Brocade.
However, the ususal caveats apply: no F-port-trunking-channeling
Rigido1971
Thank you all for the replies.
Actually we were able to set the Nexus (NX-OS 6.0(2)n2(3)) to interop-mode 3 and the Brocade (FOS v7.1.0c) with Core PID enabled (1), as we set the Brocade port to R_RDY mode the E_PORT came up and all the zoning info passed from the Brocade to the Nexus. We tried to make the Nexus as the Principal for the fabric (we are in a lab environment) and tried to create some fcalias, zoneset and all passed to the Brocade.
We're testing this for a migration purposes so we can't change the Brocade config, we just need to find a way to make the Nexus join the actual fabric in a nondisruptively mode...and it looks like this config is working as we would expect.
The questionis: We hope we will never need support but, just in case, will Cisco give us support for such configuration? :)
Thank you once again.
  FCP
  F-port trunking
  F-port channeling
  VSAN trunking
  In-order delivery
  Port tracking
  Standard zoning
  Port security
  Domain and port
  Enhanced zoning
  SAN PortChannels
  Fibre Channel ping
Btw. here is the Cisco Interop. Matrix
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/interoperability/matrix/intmatrx/Matrix5.html
