nexus FcoE config
bmarms
can someone tell me if the attached diagram is supported?  i am having issues getting the fc connection funtioning from the host hba to the brocade fabric.
bmarms
diagram corrected
AFAIK that configuration is not supported. Even if it were technically feasible, no storage vendor would support that architecture.
Rgds
usujlana
I do not think you can have cascaded NPV switches connected to a NPIV switch. Again I would have to defer
From the below doc it says :
Connectivity from an FCoE NPV bridge to the FCF is supported only over point-to-point links."
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/mkt_ops_guides/513_n1_1/n5k_ops_fcoe.html
Hope this helps.
~upinder
Amit Singh
Nested NPV not supported. Even with UCS FI, we always want NPV - NPIV to work point to point and have the FI's directly connected to the SAN switch and provide flogi/DCID services.
Cheers,
-amit singh
