Nexus - NX-OS IfDescr interface FC?
vgaraboa
Hi.
Can I using snmp (snmpwalk) to test interfaces Fibre Channel (fc1/10) on NX-OS (7.0.2)?
I can view the IfIndex using 'show interfaces snmp-index', but if I use snmp and snmpwalk I can't locate any info about these interfaces.
Thanks in advance.
Vgaraboa.
jihicks
Hi Vgaraboa,
.1.3.6.1.2.1.2.2.1.2
ifDescr OBJECT-TYPE
	-- FROM	IF-MIB
	-- TEXTUAL CONVENTION DisplayString
	SYNTAX		OCTET STRING (0..255)
	DISPLAY-HINT	"255a"
	MAX-ACCESS	read-only
	STATUS		Current
	DESCRIPTION    "A textual string containing information about the
               interface.  This string should include the name of the
               manufacturer, the product name and the version of the
               interface hardware/software."
::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) interfaces(2) ifTable(2) ifEntry(1) 2 }
Example:
snmpbulkwalk  -v2c -c public <ip address removed> 1.3.6.1.2.1.2.2.1.2
IF-MIB::ifDescr.16777216 = STRING: fc1/1
IF-MIB::ifDescr.16781312 = STRING: fc1/2
IF-MIB::ifDescr.16785408 = STRING: fc1/3
IF-MIB::ifDescr.16789504 = STRING: fc1/4
Best regards,
Jim
Hi Jim.
Thanks for your answer. I'm using just what you say, but when I try to find any info of our FCx/x interfaces, nothing appears.
I tried to do a total smwbulk query to NX, and same result, I could not see nothing of these interfaces.
Victor.
Hi Victor,
Sounds like you might be hitting this bug, CSCup75270 -  FC interfaces are not listed in IF-MIB snmp walk.
Link to it on Cisco Online:
https://tools.cisco.com/bugsearch/bug/CSCup75270
If this doesn't match, can you give me a little more information.
What Nexus product are you using ( model number )?
What version of firmware is running on the switch ( show ver )?
What interfaces are configured to be native Fibre Channel?
Jim
Hi Jim.
You're right, our Nexus N5K-C5548UP has the OS version 7.0(2)N1(1).
Thanks for the bug link.
Víctor.
